UI Tools Library
Introduction
libUITools is a small AIMMS library, with prefix uit, for applications that move from WinUI to WebUI. It contains two tools:
Progress reporting in WinUI and WebUI. The procedure
uit::pr_DialogProgresshas the same arguments asDialogProgress(), and works in both user interfaces. This way, the WinUI version of the application keeps working while you convert it.A notification manager. Instead of showing a message dialog per finding, the model adds a notification to a list with
uit::pr_addNotification. The library has a WebUI page that shows the list, where the user can mark notifications as handled and open the related pages.
The conversion process itself is described in Converting a WinUI Application to WebUI.
Instructions
Adding the library to your project
The download contains the library only: its Project.xml, the model file libUITools.ams, and the WebUI page of the notification manager.
Download the zip file, and unpack it in your project folder. This gives a folder
ui-tools-library.In AIMMS Developer, add that folder as a library with .
When your project is in git, you can add the repository as a git submodule instead, so that updates of the library are easy to take over.
Trying the example
The project 717-ui-tools-test shows both tools in a small model, with a copy of the library:
Download the project as a zip file, open
UIToolsTest.aimms, and open the WebUI.On the home page, click
button_test_progressto see the progress message, andbutton_test_notificationto add a few notifications.Open the page NotificationHandling, below libUITools in the page tree, to see the notifications.
Reporting progress in WinUI and WebUI
The library decides which user interface to address with two flags:
uit::bp_useWebUI: 1 when the application runs in the WebUI. Its initial value is 1.uit::bp_useWinUI: defined as1 - uit::bp_useWebUI.
The procedure uit::pr_DialogProgress( message, percentage ):
in WinUI mode, calls
DialogProgress( message, percentage ),in WebUI mode, calls
webui::SetProgressMessagewith the message, the percentage, and a bar of ten blocks, for exampleSolving 40% [████______].
The percentage is optional. When you leave it out, the WebUI shows the message with 0% and an empty bar.
To use it, replace each call DialogProgress( in your model by uit::pr_DialogProgress(. This is a typical routine change to ask SENSAI for:
In all procedures of the model and its libraries, replace each call to DialogProgress by a call to uit::pr_DialogProgress, with the same arguments.
As long as the application also runs in WinUI, set the flag to match the user interface. For example, set it in the procedure that runs when the WebUI loads its first page: in the WebUI, open the page settings of the home page, and set the procedure upon load:
Procedure pr_openHomePage {
Body: {
uit::bp_useWebUI := 1 ;
webui::OpenPage( 'first_page' );
and set uit::bp_useWebUI := 0 in the startup procedure of the WinUI version.
You can also use the flags for other code that differs between WinUI and WebUI.
Notifications
Add a notification with one call per finding:
uit::pr_addNotification(
sp_message : "Capacity of plant P1 is negative",
ep_severity : 'warning',
bp_preventsSolve : 1,
ep_page1 : 'plant_data',
ep_page2 : '');
Each notification has:
sp_message: the message. This is the only required argument.ep_severity:info(the default),warningorerror.bp_preventsSolve: 1 when not handling the notification likely prevents a successful solve. The default is 0.ep_page1andep_page2: up to two pages, fromwebui::AllPageIds, where the user can fix the cause. The second page is useful when two related items are not on the same page.
The library also keeps, for each notification, whether it is handled, when it was created, and when it was last marked as handled.
The notifications live only during the session. The library is not saved in a case, so the list is empty when the application starts again, or when a case is loaded.
The library page NotificationHandling shows the notifications in a table:
The page actions Show all and Show unhandled filter the table.
The actions of a row toggle the notification between handled and not handled, delete it, or open its first or second page. The column handled cannot be edited directly in the table: use the row action toggle handled, which also records the date.
To start a check from an empty list, call uit::pr_clearNotifications first. Otherwise, running the same check again adds the same notifications a second time:
Procedure pr_checkData {
Body: {
uit::pr_clearNotifications ;
if p_capacity( 'P1' ) < 0 then
ep_severity : 'warning' );
endif ;
Opening the notifications page
The page is part of the library, below the page libUITools in the page tree. Its slug is uit::notificationhandling. Make it easy to reach, for example:
as a step in a workflow panel, or
by opening it after a data check:
webui::OpenPage( 'uit::notificationhandling' );
For when to use notifications instead of dialogs, see Presenting many messages as notifications.
Minimal Requirements
AIMMS 26.8 and the WebUI library 26.10 or newer.
AIMMS Community license is sufficient for working with this library.
Release Notes
- v1.0 (26/11/2026)
First release as a toolkit library:
uit::pr_DialogProgress, and the notification manager withuit::pr_addNotificationanduit::pr_clearNotifications.
