HTTP Client Library
Since AIMMS 24, the HTTP Client Library is no longer supported. See also AIMMS Product Lifecycle
The HTTP Client Library allows AIMMS applications to communicate with web services and APIs over the HTTP protocol. It enables the sending and receiving of data between AIMMS models and external web services, enhancing the capability to integrate real-time data and perform web-based interactions. This library is useful for incorporating external data sources, automating data exchanges, and expanding the functionality of AIMMS applications through web connectivity.
Here, you can find documentation about it:
- Using HTTP Client Library
- Extract Data from an XML File
- Extract XML File from a Server with the HTTP Library
- Retrieve Geographic Data with Google Maps API
- Retrieve Geographic Coordinates with Google Maps API
- Extract Photos Using the Flickr API
- Convert Audio File with IBM API
- Use the IBM Image Recognition API
- Integrate AIMMS with Models Built in Languages Like Python or R
- Integrate AIMMS with Python
- Integrate AIMMS with R
