Sudden Microsoft Access reporting: “make sure this is a valid datasource”¶
Symptom¶
As of September 2020 some customers are reporting, from a project that used to work smoothly:
Opening table ....
from data source "DRIVER={Microsoft Access Driver (*.mdb, *.accdb ....
make sure this is a valid datasource.
Diagnose¶
Using the ODBC data sources (64 bit) app, try to create a system dsn to the Microsoft Access database file. When the error message:
The setup routines for the Microsoft Access Driver (*.mdb, *.accdb) ODBC driver could not be loaded due to system error code 1114:
A dynamic link library (DLL) initialization routine failed.
(C:\Program Files\Microsoft Office\root\VFS\ProgramFilesCommonX64\Microsoft Shared\Office16\ACEODBC.DLL).
appears, this indicates an installation error.
Fix¶
The following tip from stackoverflow may help:
Settings -> Add/Remove Programs-> Select “Microsoft Access database engine” and select Modify.
