Version Control in AIMMS Projects
Introduction
Effective version control is essential for managing AIMMS projects, enabling collaboration, tracking changes, and maintaining project integrity. With AIMMS supporting text-based source files from AIMMS 4, up to the latest version, it is easier than ever to integrate a Version Control System (VCS) such as Git into your workflow.
This article provides best practices for using version control in AIMMS projects, including setup instructions using SourceTree, a user-friendly Git client.
Why Use Version Control?
Version control offers numerous benefits, including:
Tracking Changes: Maintain a detailed history of changes, allowing easy review and rollback.
Collaboration: Multiple developers can work on the same project without conflicts.
Branching and Merging: Experiment with new features in separate branches and merge them once finalized.
Backup and Recovery: Protect your work against accidental loss or corruption.
Setting Up Git with SourceTree for AIMMS Projects
Follow these steps to set up Git version control for your AIMMS project using SourceTree:
1. Install Git and SourceTree
Download and install Git for Windows
Download and install SourceTree
2. Initialize a Git Repository for Your AIMMS Project
Open SourceTree.
Click .
Select the folder where your AIMMS project is stored.
Click to initialize a Git repository in that folder.
3. Configure Remote Repository (Optional, for Collaboration)
To collaborate with others, push your project to a remote Git repository (e.g., GitHub, GitLab, Bitbucket):
Create a repository on GitHub/GitLab/Bitbucket.
In SourceTree, go to .
Click and enter the remote repository URL.
Click to upload your local repository to the remote server.
4. Add and Commit Files
In SourceTree, go to the tab.
You will see untracked files (your AIMMS project files).
Select all files and click .
Enter a commit message (e.g., “Initial commit”) and click .
Best Practices for Managing AIMMS Projects in Git
Use Meaningful Commit Messages: Clearly describe what each commit changes.
Ignore Unnecessary Files: Add a
.gitignorefile to exclude unnecessary files (e.g., temporary AIMMS files).Work in Branches: Use branches for feature development and bug fixes.
Regularly Push Changes: Keep your remote repository updated to avoid losing progress.
Review Before Merging: Use pull requests or merge requests to review code before merging branches.
Backup Strategies Without Using a VCS
If you do not use a VCS, consider:
Zip Archives: Create zip backups of your AIMMS project folder.
Automated Backup Scripts: Use command-line scripts to generate time-stamped zip backups.
Aimmspack files are not suitable for version control, once you create your aimmspack, your files are encrypted, preventing meaningful tracking of changes.
Aimmspack files primarily serve two main purposes in AIMMS:
Deployment: Packaging all development sources into a single file.
Encryption: Protecting intellectual property.
Conclusion
Integrating Git with AIMMS projects improves collaboration, tracking, and project management. By using SourceTree, developers can manage AIMMS source files easily and benefit from a robust version control workflow.
