Libraries Initialization and Termination
When an AIMMS application is launched, the initialization procedures are executed before all else. Likewise, when the app is shut down the termination procedures are executed.
See also
If you want some action to happen each time you open the app, such as reading data from a database, you can integrate this functionality into the one of the AIMMS initialization routines. A thoughtful model builder, before coding, may consider the questions:
But which AIMMS initialization procedure (design)?
And what are the consequences of placing such a call in an initialization procedure (evaluate)?
And does it make sense to place a data read procedure in the initialization (evaluate)?
The purpose of this article to give you a better understanding of the initialization and termination of an AIMMS app. With this understanding, you can provide an informed answer to the above questions and to the questions below, in the context of the app being developed:
Which are the initialization procedures available to an application (knowledge)?
When can you rely on a library to be initialized (understanding)?
Does the order in which libraries are declared matter to the initialization and termination of an application (understanding)?
Do initialization and termination depend on the way the application is deployed (knowledge)?
How to stop a running application (knowledge)?
In this article, the above questions are not answered directly. Please use the project below to follow this article’s explanations.
The pr_visit Procedure
The purpose of the procedure pr_visit is to mark the visiting procedures. The procedure pr_visit has the following simple code:
1p_visits += 1 ;
2sp_node := callerNode(1);
3sp_line := formatString("Visit %2i from: %s", p_visits, sp_node);
4pr_log(sp_line);
whereby the procedure pr_log outputs the line either into the session log or to a local file, depending on how the app is called.
Subsequently, a call to pr_visit is placed at every procedure that might be involved in the initialization or termination.
Running the InitTerm Application
To test, please open the application, click on “solve” button and close AIMMS. The visit.txt file will be:
1Visit 1 from: MainInitialization
2Visit 2 from: a::LibraryInitialization
3Visit 3 from: b::LibraryInitialization
4Visit 4 from: c::LibraryInitialization
5Visit 5 from: d::LibraryInitialization
6Visit 6 from: PostMainInitialization
7Visit 7 from: a::PostLibraryInitialization
8Visit 8 from: b::PostLibraryInitialization
9Visit 9 from: c::PostLibraryInitialization
10Visit 10 from: d::PostLibraryInitialization
11Visit 11 from: pr_startup
12Visit 12 from: pr_openPageWebUI
13Visit 13 from: pr_solve
14Visit 14 from: d::PreLibraryTermination
15Visit 15 from: c::PreLibraryTermination
16Visit 16 from: b::PreLibraryTermination
17Visit 17 from: a::PreLibraryTermination
18Visit 18 from: PreMainTermination
19Visit 19 from: d::LibraryTermination
20Visit 20 from: c::LibraryTermination
21Visit 21 from: b::LibraryTermination
22Visit 22 from: a::LibraryTermination
23Visit 23 from: MainTermination
There are several remarks to be made about this log:
The order in which the libraries are initialized is top to bottom, and in which they are terminated is bottom to top.
Tip
Consequently, it is practical to put the system libraries
AimmsProLibraryandAimmsWebUIat the top of the library list. This permits other libraries to use the functionalities of these libraries even in theirLibraryInitializationandLibraryTerminationprocedures.On line 13 the procedure
pr_solveis visited.Once closed the application, AIMMS initiates the shutdown of the session (lines 14-23).
If there is a number jump just before PostMainInitialization, this implies that a startup case is loaded when opening AIMMS.
Deployment Dependent Actions Taken
The following lists which actions are taken by application start or application finish:
Developer |
WebUI |
Solver |
AimmsCmd |
runonly |
MainInitialization |
LibraryInitialization |
Load of startup case |
PostMainInitialization |
PostLibraryInitialization |
Startup procedure |
Page open of WebUI page |
Page close of WebUI page |
Read input case |
Write output case |
PreLibraryTermination |
PreMainTermination |
MainTermination |
The columns of the above table are:
AIMMS Developer: the actions taken by AIMMS Developer by opening and closing the
InitTermapplication.WebUI: the actions taken by a WebUI application published on AIMMS Cloud by opening and closing the
InitTermapplication.Tip
Many users appreciate a quick start of an application as this will as this will put them at ease knowing that the system is up and running. In addition, they appreciate progress information during a long running data read procedure, perhaps via webui::SetProgressMessage. Please consider placing long running data read procedures as an explicit action to be invoked by the user.
A published WebUI app can be closed in two ways:
By running the procedure
pro::sessionmanager::FinishSession().By closing all browser tabs, and waiting a minute.
Solver: A solver session submitted by
pro::delegateToServer.The input case is the case constructed by the data session (WinUI or WebUI) to provide input to the solver session.
The output case is the case constructed by the solver session to pass the results to the data session.
Tip
It may be redundant to read in data in an initialization procedure of a solver session when that data is also provided in the input case.
AimmsCmd: Running the
InitTermapplication via AimmsCmd and just opening and closing it.runonly: Running
aimms.exewith the –run-only command line argument (using AIMMS 4.87.4 or newer).
