Speed Up MIP Solve
When you have a weak LP relaxation, or a hard LP problem that needs to be solved for your MIP problem, solving the problem can take a long time.
There are several reasons why the MIP algorithm can take a long time. Some of them are:
The MIP solver cannot handle this math program very well.
The LP relaxation is very weak and therefore there are only a few cuts in the branch-and-bound tree.
Solving the LP problems is relatively hard.
If the branch-and-bound tree becomes very large, the solver needs to swap memory, which decreases the performance drastically.
Solver
You could try to run your model with a different MIP solver. For many MIP models CPLEX and GUROBI perform better than CBC and XA.
Reformulation
If you have a weak LP-relaxation, you should look again at your model formulation. Maybe you can decrease the use of Big M coefficients in your model, or maybe you can add some cuts.
If you have a very large LP that takes a relatively long time to solve, you could try to solve the LPs on the nodes using the Barrier algorithm.
Go to set the following option: .
Priorities
If your model includes natural priorities (because some decisions follow from or follow up other decisions), you could decide to make use of these priorities. See also The Priority, Nonvar and RelaxStatus Attributes.
Starting Solution
When you are able to create a good starting solution (e.g. using a heuristic), you can provide the solver with this solution to improve the solution process.
Note that this is only possible when you use CPLEX, Gurobi, COPT or CBC.
Go to to set the following option:
CPLEX: Advanced Start to ‘Use advanced basis’
Gurobi: MIP Start to ‘Yes’
COPT: MIP Start to ‘Use full solutions’ or ‘Use partial solutions’
CBC: MIP Start to ‘On’
By enabling solver logging you can check whether the solver is accepting the MIP start (except for CBC). To do so, set the Solvers General option
Solver Listing Messages (for AIMMS Developer), or
Solver Window Messages (for AIMMS Cloud)
to ‘All’, and set the following solver option:
CPLEX: MIP Display to ‘Display each nth node’
Gurobi: Output File to ‘Yes’
COPT: Output File to ‘Yes’
If CPLEX accepts the MIP starts then it will show in its status file:
1 of 1 MIP starts provided solutions.
MIP start 'm1' defined initial solution with objective 21.0000.
If Gurobi accepts the MIP starts then it will show in its log file:
Loaded user MIP start with objective 21
If COPT accepts the MIP starts then it will show in its log file:
Loading 1 initial MIP solution
Initial MIP solution # 1 with objective value 21 was accepted
Note: CPLEX and Gurobi can use multiple MIP starts, see:
CPLEX: Multiple MIP Starts
Gurobi: Multiple MIP Starts
