AIMMS API
Warning
This article references outdated technology and is provided for historical purposes only. It is not recommended to use this information as a primary source for current projects or documentation. Please refer to the latest documentation for up-to-date information.
Direct download AIMMS Project AIMMS API.zip
This AIMMS project illustrates the basic use of the AIMMS API in an external DLL.
The model contained in this example project refers to the external C function illustrated in the AIMMS Language Reference, and its associated declaration in an AIMMS model.
For illustration this demo uses a tiny dataset for a small set of Cities, and a single parameter TransportCost, both initialized in the model. On the demo page you can extend the set of Cities, and introduce additional non-zero elements for the identifier TransportCost.
The call to the external DLL will retrieve all data for the parameter TransportCost (and of the set Cities used in its domain) using the AIMMS API. The output generated by the external DLL for the identifier TransportCost is written to the file “TransportCost.def”.
The import library libaimms.lib that is provided in the AIMMS API directory of your installation, is compiled for Visual Studio 2005. If you are using a different C compiler, please create a dummy libaimms.dll DLL from the file libaimms.c provided in the Source directory of this project. Subsequently, you can use the import library libaimms.lib created by your compiler to execute the link step successfully.
Keywords: AIMMS API, external DLL
