Modifying Session Timeout Duration for WebUI Apps
WebUI sessions have a default timeout timer that will end an idle data session after 300 seconds (5 minutes) with checks being made every 10 seconds.
To change this setting you can add a .txt file in the project’s main folder with the name webui-check-alive-settings.txt.
In this file you can specify the timeout timer with the format “time before ending session(seconds)” “interval checks(seconds)”.
For example: 600 10 would terminate the session after 10 minutes with checks made every 10 seconds.
Ending a Session Explicitly
The timer is not the only way a session ends. To close one from the model:
WebUI apps:
pro::sessionmanager::FinishSessionWinUI apps:
ExitAimms
Note that after a logout a WebUI session stays active for a further five minutes before it is deactivated.
