This is a WinUI app, and when you select the storage tab, the screen looks as follows:
For individual files (objects) and folders (buckets) you can alter the authorization, add them or delete them.
When you delete a folder (bucket), you delete all its files and subfolders.
If you change the authorization of a folder (bucket), you do not change the authorization of its files or subfolders.
The default setup is such that users that are not members of the group Admin, ordinary users for short, cannot read the folder /userdata. To provide them with this access, a user that is the admin, or a member of the group Admin, can provide Read access to all of the folder /userdata and of the direct sub folders corresponding to the environments. Note that the consequence of this action is that a user sees which other users are on the AIMMS Cloud. This may, or may not, be a violation of the security protocols; and is therefore not provided by default.
AlterAuthorization is a WinUI app that starts with the following screen:
There are four buttons that allow you to operate this app:
SelectTargetFolder. This will bring up the following dialog:
In this dialog you can click on:
A number, then you will get in the indicated subfolder.
The button up; then you will go up one level in the directory structure.
The button cancel, ignore changes made in the dialog.
The button ok, accept changes made in the dialog.
Selectmydata. Directly select the folder /Userdata/<env>/<username>
The reason for this button is, as explained above, that ordinary users cannot read the folder /Userdata.
They can, however, browse through it. This button does just that to land at one own’s files.
SpecifyAuthorization. In this dialog you can specify an authorization to be used.
To select a new authorization, you should:
Select the environment, in the example AIMMS is selected.
Select a user, or a group of users. In the example, the user Chris is selected.
A new entry appears in the table CurrentAuthorization. Here you can check/uncheck tick marks as required.
Alterauthorizationfilesandfolders. Pressing this button will apply the authorization specified to the target folder specified and all files and folders therein.
Last updated: Mar 26, 2026
Help & Feedback
Docs
Edit this page to fix an error or add an improvement in a pull request
Create an issue to suggest an improvement to this page
