Install and Configure a AIMMS Network License
Installing the AIMMS Network License Server
A network license is administrated by the AIMMS Network License Server on a server computer.
Download the AIMMS Network License Server from AIMMS Downloads.
Run the
AimmsLicenseServer...msiinstallation file and follow the prompts in the Installation Wizard.
Installing the Network License via License Manager
Run the AIMMS License Manager.
In AIMMS Network License Manager, go to .
Go to .
A dialog appears.
Follow the License Install Wizard prompts to install your license.
License Number - Enter your license number
License Protection - Select activation code
Activation Code - Enter your activation code
Nodelock Protection - Machine Nodelock is recommended for this license type
Communication Method - If you are connected to the internet, Online activation is the fastest and easiest method. If you do not have internet access, choose Offline activation and complete activation later.
If you choose Offline communication, a request file is generated. You must go to AIMMS Offline License Activation and submit the request file to complete activation.
The license is now installed and appears in the AIMMS Network License Manager.
Configuring License and Adding Users
You can rename license profiles with nicknames. Single-click twice on the profile name to edit.
Add users in . For further instructions, read Named Users in License Manager.
Go to to exit . The service should start automatically. To double-check, go to .
A dialog confirms “Service is already running.”
If a message appears saying “Unable to Start the service,” go to .
Users can access an AIMMS Network License while connected to the network from any machine, if they are logged in with credentials that are registered in the AIMMS Network License Manager as Registered Users.
