Uponchange with Arguments
This article illustrates how to use uponchange annotation with arguments. This can be beneficial when there are block-editing and consistency check per value.
Note that this is a WebUI feature only. Changes on WinUI or directly on the AIMMS IDE will not trigger the uponchange procedure.
Step 1
Create a procedure with the following input arguments. Set both identifiers’ index domain to the same index domain of the identifier to be triggered.
This case, a generic i_i, i_j and i_k is used. Everytime that the user change one or multiple values, this procedure will be triggered.
Procedure pr_triggersOnUponChange {
Arguments: (bp_in_hasChanged,p_in_oldValue);
Parameter bp_in_hasChanged {
IndexDomain: (i_i,i_j,i_k);
Range: binary;
Property: Input;
Parameter p_in_oldValue {
Property: Input;
Remarks:
p_in_oldValueis a copy of the triggered identifier, so if the triggered one is a parameter, this will be also, same for other types of identifier.bp_in_hasChangedis a binary argument that will return which values where changed.Both arguments can be names as you wish, but always the first will return if it was changed and the second the old value of the identifier.
Step 2
When adding arguments to the uponchange procedure, consistency checks are possible, but you can also only let the customer knows what was just changed.
1empty sp_whatHasChanged;
2
3sp_whatHasChanged := FormatString("Number of values changed: %n.\n", card(bp_in_hasChanged));
4
5for ((i_i,i_j,i_k) | bp_in_hasChanged(i_i,i_j,i_k)) do
6 sp_whatHasChanged
7 += FormatString("p_anyData(%e,%e,%e) changed from %n to %n.\n",
8 i_i,
9 i_j,
10 i_k,
11 p_in_oldValue(i_i, i_j, i_k),
12 p_anyData(i_i, i_j, i_k));
13endfor;
Remarks:
sp_whatHasChangedis used to clarify that only data selected was changed.
See also
