Publishing, Running and Deleting Apps on AIMMS Cloud
This article provides an example of Python code that can be used to publish a project, run a specific task on it and delete the published project.
Use Case?
“When using a CI/CD pipeline” you may want to test the app as follows:
Publish
Run scenario
Cleanup (including removing the app)
Below, you will find a code example of how to achieve this.
import requests
import time
import os
url = "https://YOURURL-test.aimms.cloud/pro-api/v2/"
url_tasks = "https://YOURURL-test.aimms.cloud/pro-api/v2/"
url_scope = "applications"
project_name = 'YOURPPROJECTNAME'
project_version = time.strftime("%Y%m%d%H%M%S") #Creating a unique name for publishing
# Publishing
file_location = './PROJECTNAME.aimmspack'
files = [
('file', ('PROJECTNAME.aimmspack',
open(file_location, 'rb'),
'application/octet-stream'))
headers = {
'apiKey': 'YOURAPIKEY'
payload = {'metadata': '{"name": "' + project_name + '", "description": "YOUR DESCRIPTION", "projectVersion": "' +
project_version + '", ' '"aimmsVersionId": "4.91.2.8-linux64-x64-cm_vc141", "projectCategory": "YOUR CATEGORY" }'}
# replace 4.91.2.8-linux64-x64-cm_vc141 with the version you would like to use
# you can view available versions of AIMMS via a Rest API call to /aimms-versions
url_publish = url + '/' + url_scope
response_publish = requests.request("POST", url_publish, headers=headers, data=payload, files=files)
print(response_publish.text)
# Runnning task
url_scope = 'tasks'
url_taskname = 'runScenarioTest' #Replace with the taskname used in the AIMMS project
url_run = url_tasks + '/' + url_scope + '/' + project_name + '/' + project_version + '/' + url_taskname + '/'
response_submit = requests.request("POST", url_run, headers=headers)
print(response_submit.text)
sp_id = response_submit.json()['id']
url_poll = url_tasks + '/' + url_scope + '/' + sp_id + '/'
state = ""
print("state:")
while state != "completed": #loop to track state of task until done
time.sleep(10)
response_poll = requests.get(url_poll, headers=headers)
state = response_poll.json()['state']
print(state)
url_response = url_tasks + '/' + url_scope + '/' + sp_id + '/' + 'response'
response_task = requests.get(url_response, headers=headers)
print(response_task.text)
# Cleaning up
url_delete = url + '/' + url_scope + '/' + project_name + '/' + project_version + '/'
response_delete = requests.request("DELETE", url_delete, headers=headers)
print(response_delete.text)
