Test Driven Development using the AIMMSUnitTest Library
This article discusses some elements from the popular software methodology Test Driven Development in relation to the AIMMS Library AIMMSUnitTest.
Gather requirements from stakeholders
What are small examples?
What are the edge cases, including error cases, performance?
Implement requirements as unit tests and see them fail!
Development
Write the code for the functions
Execute tests and see them pass!
Refactor until performance is acceptable.
Repeat
Unit tests in AIMMS projects
Prepare your AIMMS project with the below steps to declare unit tests.
Add repository library
AIMMSUnittest, seeCreate a new library that holds the actual code
Create another new library containing tests on the actual code
Make sure all tests can be run, for instance by specifying
MainExecutionas shown below:Procedure MainExecution { Body: { EnvironmentSetString("aimmsunit::RunAllTests","1"); aimmsunit::TestRunner; } }
Example: implement “mean”
Prototype the requirements
The mean should return the average value of a series of numbers.
Input check: input should not be empty.
Prototype
SelfDefinedMean(As bothmeanandaverageare key words in AIMMS, we need to come up with a new name):Function SelfDefinedMean { Arguments: (p); Body: { raise error "Not implemented yet"; SelfDefinedMean := 0 ; } Parameter p { IndexDomain: i; Property: Input; } Set S { Index: i; } }
This is a dummy implementation, a function that meets the prototype requirements, but will obviously fail. Having a dummy implementation allows us to code the tests as detailed below.
Write the tests
Small example test: Mean( 3, 5, 13 ) = 7
1Procedure pr_Test_Small_Example { 2 Body: { 3 S := data { a, b, c }; 4 P := data { a: 3, b : 5, c: 13 }; 5 r := ml::SelfDefinedMean( P(i)); 6 aimmsunit::AssertTrue("The average of 3, 5, and 13 is 7.", r=7); 7 } 8 Comment: "first test: Mean( 3, 5, 13 ) = 7"" aimmsunit::TestSuite: MeanSuite; 9 Set S { 10 Index: i; 11 } 12 Parameter P { 13 IndexDomain: i; 14 } 15 Parameter r; 16}
Note that the
aimmsunit::AssertTruestatement (line 6) is after the call toml::SelfDefinedMean.Edge case test: an empty series of numbers
1Procedure pr_Test_Empty_List { 2 Body: { 3 aimmsunit::AssertThrow("The average of an empty list cannot be computed."); 4 S := data { }; 5 P := data { }; 6 r := ml::SelfDefinedMean(P(i)); 7 } 8 Comment: "Edge case, empty list."" aimmsunit::TestSuite: MeanSuite; 9 Set S { 10 Index: i; 11 } 12 Parameter P { 13 IndexDomain: i; 14 } 15 Parameter r; 16}
Note that the
aimmsunit::AssertThrow(line 2) statement is before the call toml::SelfDefinedMean.
Collecting tests in a suite
The annotation aimmsunit::TestSuite: MeanSuite is added to the test function.
You can add annotations this way:
Click add annotation in the attribute window
Select
aimmsunit::TestSuiteType in the name of the suite. In this example, we only use one suite:
MeanSuite
Test suite before coding
Now, run the tests and with the above implementation of ml::SelfDefinedMean.
They will fail as expected.
Example result in file: log/AimmsUnit.xml
1<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
2<testsuites>
3 <testsuite id="1" name="MeanSuite" timestamp="2019-04-09T08:26:10" tests="2" errors="2" time="0.002">
4 <testcase name="tml::pr_Test_Small_Example" time="0.001">
5 <error message="Not implemented yet."/>
6 </testcase>
7 <testcase name="tml::pr_Test_Empty_List" time="0.001">
8 <error message="Not implemented yet."/>
9 </testcase>
10 </testsuite>
11</testsuites>
There are several remarks about this file:
On line 3, which suite and which tests are run, it is also important the number of tests that failed. All the tests failed as expected (errors =”2”) and we can start coding the function now.
In lines 4 - 9, we see the details of the failure of our two tests. As the function hasn’t been implemented yet, it raised an error message in both the tests.
Code the function
Mean is calculated by dividing the sum of the records by the count of records. This is implemented in the code below:
1Function SelfDefinedMean {
2 Arguments: (p);
3 Body: {
4 p_NoElements := card(p);
5 if p_NoElements then
6 SelfDefinedMean := sum( i, p(i) ) / p_NoElements;
7 else
8 raise error "The average of an empty list cannot be computed." ;
9 SelfDefinedMean := 0 ;
10 endif ;
11 }
12 Parameter p {
13 IndexDomain: i;
14 Property: Input;
15 }
16 Set S {
17 Index: i;
18 }
19 Parameter p_NoElements;
20}
Running the test now gives the following results:
1 <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
2 <testsuites>
3 <testsuite id="1" name="MeanSuite" timestamp="2019-04-09T09:31:16" tests="2" time="0.002">
4 <testcase name="tml::pr_Test_Small_Example" time="0.001"/>
5 <testcase name="tml::pr_Test_Empty_List" time="0.001"/>
6 </testsuite>
7 </testsuites>
The log indicates that both the tests passed without any issue. So, everything is good to go. Or is it?
Fix a bug
However, soon one of our stakeholders comes with a question:
Why does
ml::SelfDefinedMean(3, 5, 0, 12)return 6.67 instead of 5?
Apparently, our set of requirements does not consider all edge cases. Now we will iterate on this by adding another requirement and test:
0 is a possible observation, and should count in the number of observations. So,
SelfDefinedMean(3, 5, 0, 12) = 5
1Procedure pr_Test_Zero_In_Observations {
2 Body: {
3 S := data { a, b, c, d };
4 P := data { a: 3, b : 5, c: 0, d: 12 };
5 r := ml::SelfDefinedMean(P(i));
6 aimmsunit::AssertTrue("The average of 3, 5, 0, and 12 is 5.", r=5);
7 }
8 Comment: "third test: Mean( 3, 5, 0, 12 ) = 5"" aimmsunit::TestSuite: MeanSuite;
9 Set S {
10 Index: i;
11 }
12 Parameter P {
13 IndexDomain: i;
14 }
15 Parameter r;
16}
Running the test suite again gives the below result:
2<testsuites>
3<testsuite id="1" name="MeanSuite" timestamp="2019-04-09T09:59:31" tests="3" failures="1" time="0.003">
6 <testcase name="tml::pr_Test_Zero_In_Observations" time="0.001">
7 <failure message="The average of 3, 5, 0, and 12 is 5."/>
8 </testcase>
9</testsuite>
10</testsuites>
Our unit test reproduces the bug. See failures=”1” in line 3. Notice the difference between failures and errors in the test report. Clearly, the mistake in the above implementation is that we divided by
card(P)- the cardinality of the parameter which only counts non default values instead ofcard(S)- the cardinality of the set which counts all the elements.
So, the function is updated as shown below:
2 Arguments: (p);
3 Body: {
4 p_NoElements := card(S);
7 else
10 endif ;
11 }
12 Parameter p {
13 IndexDomain: i;
14 Property: Input;
15 }
16 Set S {
17 Index: i;
18 }
20}
Running the test suite now should give the below result which indicates that the problem was fixed.
2<testsuites>
3 <testsuite id="1" name="MeanSuite" timestamp="2019-04-09T10:03:07" tests="3" time="0.003">
6 <testcase name="tml::pr_Test_Zero_In_Observations" time="0.001"/>
7 </testsuite>
8</testsuites>
All the previously written tests (before this latest change) were also automatically run, saving us time and effort. The example project can be downloaded below:
