Get Log Files
Things don’t always go according to plan. Sometimes the log files can answer What happened?
Security notice, see: Apache log4j vulnerability does not affect AIMMS Optimization Tooling
This article explains where you can find various log files in your project.
Logs for the AIMMS IDE
The project log folder is a good place to start the search.
This folder is by default the subfolder log of the project folder.
This folder can be redirected by setting the project option Listing and temporary files.
The project/log folder contains the following files:
File
aimms.errThis file is a recording of the error and warning messages sent to the error and warning window of the AIMMS IDE. This file is refreshed when the AIMMS project is started.File
messages.logThis file is a recording of the messages sent to the message window of the AIMMS IDE. You can increase the amount of information by activating the optionsmajor messagesandtime messages. This file is refreshed when the AIMMS project is started.File
<modelName>.lisConstraint and solution listings are written to this file. In addition, if no FILE is opened, then the output of PUT and DISPLAY statements is written to this file as well. This file is refreshed when the AIMMS project is started.File
<solver>.staThis file is a recording of the messages issued by the solver. See also solver logging. This file is refreshed when the AIMMS project is started.Folder
ErrorReportsThis folder contains so-called.dmpfiles. A.dmpfile is a recording of the state of the running threads during a severe internal error. Note that this folder is not emptied automatically by AIMMS. When zipping your project leads to large archives, it might help to delete old.dmpfiles.
Logs for deployed AIMMS app via AIMMS PRO
App launch
When the incident happened while launching an app, look at:
%LOCALAPPDATA%\AIMMS\PRO\Launcher\<Pro version no>\AimmsPROLauncher.log.txt%LOCALAPPDATA%\AIMMS\PRO\AppLauncher\<Pro version no>\ProWebLink.log
App running
When the incident happens during an AIMMS verify, client, or solver session, look at the session log.
Download button for log files can be found at on tab configuration, click Log Management.
Note that this tab is only available to users in the Admin group.
You will find the session logs (verify sessions, data sessions and server sessions) in the folder log\\Sessions after unzipping the download.
Warning
The AIMMS PRO log files are designed to be interpreted by AIMMS staff only. Please do not be alarmed if (parts of it) don’t make sense.
The download button is available since AIMMS PRO 2.11.
For older AIMMS PRO systems, you can look at the folders:
C:\ProgramData\AimmsPRO\Log\Sessions\ and C:\ProgramData\AimmsPRO\Log\ on the machine running AIMMS PRO.
further reading
Browser logs
The front end of the WebUI actually shows your User Interface and runs in a supported browser. The logging information of this component is also kept in the browser. To obtain this log information, we need to obtain this from the browser as follows:
Chrome
Ctrl-Shift-J or F12
mark all messages
right click and select “save as”
Edge
Ctrl-shift-J or right click and select “Inspect Element”
Switch to tab “Console”
Mark and copy all (relevant) text
Paste this text to a text editor, and save it as a
.logfile.
Internet Explorer 11
Right click in the browser window
Select “Inspect Element”
Select tab console
Right click in this tab, and select Copy All
Paste the copied text to a text editor and save it as a
.logfile.
License server logs
The licensing log files can be found in the folder C:\ProgramData\AIMMS\Logging\
and the log files are called LicenseServer.log LicenseServer.log.1 through LicenseServer.log.10
The license logging can be configured using LicenseServerLogging.xml in that same folder.
In this configuration file, you may want to change
<param name="ConversionPattern" value="%r %5p [%t] %m%n"/>
to
<param name="ConversionPattern" value="%d{ISO8601} %r %5p [%t] %m%n"/>
such that the timestamps of the incidents are more easily interpreted.
After this change, the license service needs to be restarted as follows:
If the license server, also serves licenses for an AIMMS PRO, stop the service of AIMMS PRO using the AIMMS PRO configurator. It may take one or two minutes before the service is stopped.
In the AIMMS License manager, stop the license service using the menu item
Maintenance > Stop the service.In the AIMMS License manager, start the license service using the menu item
Maintenance > Start the service.Start the AIMMS PRO services stopped in the first step. It may take one or two minutes before the service is started.
