Log CDM
CDM logging can be turned on for both the client and the service.
CDM Logging in the Client
Copy the file CDMLogConfig.cfg from the installation folder of the CDMService to the project folder.
Uncomment line 17 of this file.
1# PRO global log configuration
2log4j.rootLogger=INFO, file
3
4# Write appender to file (max 50MB, at most 10 backup files)
5log4j.appender.file=org.apache.log4j.RollingFileAppender
6log4j.appender.file.file=CDMLog.xml
7log4j.appender.file.ImmediateFlush=true
8log4j.appender.file.layout=org.apache.log4j.xml.XMLLayout
9log4j.appender.file.MaxFileSize=50MB
10log4j.appender.file.MaxBackupIndex=10
11
12# Special tracing for some loggers
13log4j.logger.ARMI=INFO
14log4j.logger.AIMMS=WARN
15#log4j.logger.CDMService=TRACE
16#log4j.logger.CDMDB=TRACE
17log4j.logger.CDM=TRACE
The output file CDMLog.xml is in the project folder.
CDM Logging in the Server
The CDMServiceLogConfig.cfg set the loggers of CDMService and CDMDB to TRACE (the highlighted lines):
3
6log4j.appender.file.file=/cdm/logs/CDMServiceLog.xml
11
15log4j.logger.CDMService=TRACE
16log4j.logger.CDMDB=TRACE
The output file CDMServiceLog.xml is in the folder /cdm/logs.
