Reclaim Memory Between Data Instances
An application that loads and discards large data instances in sequence - running many scenarios in one session - needs to release the memory of one before reading the next. Four statements do related but distinctly different things, and using the wrong one leaves data behind.
What Each Statement Does
Take a set s_locations with index i and parameters p_supply(i) and p_flow(i,j).
Empty s_locations;
Clears the set and every identifier depending on it - so p_supply and p_flow as well.
A second form takes a subset of AllIdentifiers. With s_ids defined as { p_supply, p_flow }, Empty s_ids; clears the data of those two parameters - not the contents of s_ids itself.
Cleanup p_supply;
Removes inactive data. If s_locations once held {a, b} and now holds {b} while p_supply still carries {a:1, b:2}, then a:1 is inactive: it belongs to an element no longer in the set. Cleanup drops it from p_supply.
CleanDependents s_locations;
Does the same across every dependent identifier and removes the name 'a' from the set’s element space. That second part matters: without it the element number stays allocated, which is why element numbering accumulates through a session.
Rebuild;
Drops unused index permutations. If p_flow’s main permutation is [i,j] and a [j,i] copy also exists - kept because it was efficient for some earlier computation - Rebuild removes the copy.
GarbageCollectStrings is the counterpart for the string table.
What “Removing” Actually Means
None of these return memory to the operating system. They move it to AIMMS’s own reserves, which are then used first the next time execution needs memory.
That is the behavior you want between data instances - the memory is reused rather than requested again - but it does mean the process size seen from outside will not drop, and that is not evidence the clearing failed.
Clearing a Data Instance
The goal is usually to clear everything belonging to the model while leaving the application’s own state - the interface, dialogs, meta-information - untouched. That distinction has to be made explicitly, because AIMMS has no notion of it.
Separate the identifiers by section, and build a subset of AllIdentifiers from those sections:
s_mainModelIds  := sectionBusinessLogic;
s_businessLogic := s_mainModelIds + s_lib1Ids + s_lib2Ids;
Then clearing an instance is three steps:
! 1. Generated mathematical programs hold memory of their own.
while card( AllGeneratedMathematicalPrograms ) do
    ep_gmp := first( AllGeneratedMathematicalPrograms );
    GMP::Instance::Delete( ep_gmp );
    AllGeneratedMathematicalPrograms -= ep_gmp;
endwhile;
! 2. The model's own data.
Empty s_businessLogic;
! 3. Strings no longer referenced by anything.
GarbageCollectStrings();
Step 1 is the one most often missed. A generated mathematical program is not reached by Empty on the identifiers it was built from, so without deleting the instances a scenario loop accumulates one matrix per iteration.
Checking for Memory Leaks
Two functions let you verify that the clearing actually works:
Record MemoryInUse() at the end of each iteration, after the instance has been cleared. Because cleared memory goes back to AIMMS’s reserves and is reused, the value should level off after the first few iterations. If it keeps growing from one iteration to the next, memory is leaking.
The leak can come from two places:
  • The application itself: some identifiers keep their data over iterations, for instance because they are not in s_businessLogic and are therefore never emptied. Calling IdentifierMemory() on the suspects, or checking their Card, shows which of them keep growing.
  • AIMMS itself: if every identifier is cleared and memory still grows, the leak is inside AIMMS. That is a bug, and should be reported to AIMMS Support together with a project that reproduces it.
Monitor Memory Usage and Leaks shows a complete pattern for logging memory over repeated runs, and Investigate Memory in Use covers the other tools for investigating memory use.
