VPN Troubleshooting Guide (Customer Side)
This troubleshooting guide is designed to help customers diagnose and resolve common issues when connecting to our Azure Virtual Network Gateway via Site-to-Site VPN.
Site-to-Site VPN issues generally fall into one of three categories, which align with the tunnel establishment process:
  • Phase 1 Failure (IKE): The two endpoints cannot agree on security parameters or authenticate, preventing the tunnel from being built. Check authentication, protocols, and firewall ports (UDP 500/4500).
  • Phase 2 Failure (IPsec): Phase 1 succeeds, but the data security association cannot be created, often due to routing or policy definition errors. Check local/remote address spaces and NAT configurations.
  • Tunnel Up, No Traffic: The tunnel is established, but packets are blocked by internal firewall rules, asymmetric routing, or subnet overlap. Check routing tables, internal firewall policies, and subnet definitions.
Problem 1: The VPN Tunnel Fails to Establish
The connection cannot be authenticated or initialized (IKE Phase 1).
Possible Causes
  • Authentication Mismatch: The Pre-shared Key (PSK) is not identical on both endpoints.
  • Incorrect Protocol: The VPN device is not configured for the required protocol (IKEv2/IPsec).
  • Firewall Blockade: The perimeter firewall is blocking IPsec/IKE traffic.
Action/Resolution
  • Verify the Pre-shared Key is identical on both your local VPN device and the Azure Gateway configuration.
  • Ensure your device is configured for IKEv2/IPsec (This is the required standard unless otherwise specified.)
  • Confirm that your firewall permits traffic on UDP ports 500 (IKE) and 4500 (NAT-T) to and from the Azure Gateway’s Public IP.
Problem 2: IKE Phase 1 Succeeds, but Phase 2 Fails
The initial authentication is successful, but the data security association (IPsec) fails due to routing or policy errors.
Possible Causes
  • Routing or NAT Issues: Address spaces are incorrectly defined or NAT rules are missing.
  • Default Route Inclusion: Advertising the default route (0.0.0.0/0) when it is not supported.
Action/Resolution
  • Ensure the Local and Remote Address Spaces defined on both sides are configured exactly as required.
  • If NAT is used, verify that the NAT rules are applied properly to the VPN tunnel interface.
  • Avoid advertising the default route (0.0.0.0/0) over the VPN unless explicitly mandated for a full tunnel configuration.
Problem 3: IP Ranges Overlap with Azure or Other Networks
Overlapping subnets create ambiguous routing, leading to connection failures or instability.
Possible Cause
  • Local and remote subnets conflict, creating routing ambiguity.
Action/Resolution
  • Change: Modify or reduce the size of the conflicting local IP ranges/subnets.
  • Translate: Implement a static NAT rule on the customer side to translate the local IP range into a non-overlapping range for traffic traversing the VPN.
Problem 4: Intermittent VPN Connection Drops
Drops indicate configuration mismatches or underlying network instability.
Possible Causes
  • Lifetime Mismatch: IKE and IPsec Security Association (SA) lifetimes are not aligned.
  • Network Stability: High packet loss or latency spikes toward the Azure VPN Gateway IP.
  • Device Limits: On-premise VPN device is struggling with high load or multiple tunnels.
Action/Resolution
  • Check Configuration: Verify that the IKE and IPsec Security Association (SA) lifetimes (in seconds or KBs) are perfectly aligned on both ends of the tunnel.
  • Check Stability: Investigate high packet loss or latency spikes toward the Azure VPN Gateway IP.
  • Check Device: Review CPU/memory utilization and performance logs on your on-premise VPN device.
Problem 5: Tunnel is Up, but Traffic is Not Flowing
The security association is established, but data packets are blocked by routing or firewall rules.
Possible Causes
  • Incorrect Routing: Missing or incorrect routes for the remote subnets.
  • Asymmetric Routing: Return routes are absent or misconfigured.
  • Local Firewall Block: Firewall rules block traffic to/from the Azure subnets.
  • Inconsistent NAT: NAT rules are missing or only applied in one direction.
Action/Resolution
  • Verify Subnets: Verify the exact subnets of the Azure Virtual Network are correctly entered into your local VPN device’s routing table.
  • Check Asymmetry: Ensure that return routes (Asymmetric Routing) are present and configured correctly on both sides.
  • Check Firewall: Confirm your local firewall rules allow traffic to and from the Azure subnets over the VPN interface.
  • Check NAT: If NAT is used, ensure that both inbound and outbound NAT rules are consistently applied to the VPN traffic.
Problem 6: Only a Subset of Subnets are Reachable
Communication is restricted to only certain parts of the Azure network.
Possible Cause
  • Incomplete Configuration: Missing routes for some intended subnets on the local device.
  • Agreement Scope: Only a subset of subnets was initially agreed upon and configured on the remote side.
Action/Resolution
  • Check your VPN device configuration for missing routes. The routing table must include all intended subnets on the remote network.
  • Review the scope of the VPN connection agreement to confirm all subnets were agreed upon and configured on the remote side.
