Conventions Used in the Examples Provided
This article just enumerates some of the conventions used in the associated example apps.
Steering the HTTP Request
To test the example apps, also on different systems, configuration of an HTTP request is arranged via a few files
in the folder Config. This folder should be located next to the project folder of the client application.
The three example clients all use this config folder to steer the HTTP requests made.
The parameters:
Common Configuration Parameters
The configuration is based on:
servicestored inservice.txt. This string parameter contains the name of the service.useCloudstored inusing_AIMMS_cloud.txt. This binary parameter is:0: iflocalhostis to be used for the service.1: if the AIMMS Cloud is to be used for the service.
Using the Service on localhost
When using the service on localhost, there is only one additional parameter relevant, namely the port number:
portstored inport.txt. This integer parameter contains the port number.
Using the Service on the AIMMS Cloud
cloudstored incloud.txt. This string parameter is a string which contains the name of an AIMMS Cloud, for instancechriskuip.aimms.cloud.apiKeystored inapikey.txt. This string parameter identifies and authorizes the user of the service. See how to obtain an apiKey.appstored inapp.txt. This string parameter contains the name of the app when published on an AIMMS Cloud, hereCountTheStars.verstored inver.txtThis string parameter contains the version of the app at hand, for instance1.0.1.0,
Methods Implemented by the Example Server App
In the example server app, there are two base methods implemented:
countStars: count the number of stars in a list of strings.
generateStars: generate a list of string with asterisks in it.
Each of these base methods can use five different de facto standards for data exchange:
CSV
Json
Parquet
Excel
XML
An actual method is by concatenating the base method with the data format. For instance,
countStarsJson is base method countStars exchanging data using data format Json.
