Routing: Capacitated Vehicle Routing Problem with Time Windows¶
Direct download AIMMS Project VRPTW.zip
Problem type: MIP (medium)
Keywords: Incumbent callback, network object
Description: The Vehicle Routing Problem with Time Windows (VRPTW) deals with the distribution of goods between depots and customers using vehicles. The vehicles have a limited capacity. Each customer has to be supplied within the time window associated with the customer.
The model formulation follows Desrochers et al. (1988), pp. 67-68.
- By default this project uses the data instance ‘R106.25’ from the Solomon set at:
More instances are available as cases.
References: Desrochers, M., J.K. Lenstra, M.W.P. Savelsbergh, F. Soumis, Vehicle Routing Problem with Time Windows: Optimization and Approximation, In: Vehicle Routing: Methods and Studies, B.L. Golden and A.A. Assad (eds), Studies in Management Science and Systems vol. 16, 1988, pp. 65-84
