Reduce Exchange Between Client Session and Solver Session
As shown in Deploy an Application on AIMMS Cloud, part of the overhead in solving is creating a case and transferring it, once from the client session to the solver session and once back. Especially, for short solves, the overhead can be relatively large. To reduce this overhead, we’ll reduce the number of identifiers that need to be passed between these sessions.
The Identifiers Needed by the Solver Session
There are three groups of identifiers needed by the solver session that can be provided by the client session:
The sets and parameters used in defining mathematical program instances to be solved
The sets and parameters used in pre-processing and post-processing these mathematical programs
The subset of
AllIdentifiersthat contains those identifiers that comprise the solution; in other words those identifiers that need to be passed back to the client session.
In the declaration below, the variables and constraints that make up the mathematical program FlowShopModel are the sets sFlowshopConstraints and sFlowshopVariables.
MathematicalProgram FlowShopModel { Objective: TimeSpan; Direction: minimize; Constraints: sFlowshopConstraints; Variables: sFlowshopVariables; } Set sFlowshopConstraints { SubsetOf: AllConstraints; Definition: AllConstraints * Flowshop_Mathematical_Program_Declarations; } Set sFlowshopVariables { SubsetOf: AllVariables; Definition: AllVariables * Flowshop_Mathematical_Program_Declarations; }
To determine which identifiers make up the mathematical program instance we need to know which identifiers are referenced in the variable and constraint definitions. We use the function ReferencedIdentifiers for this as follows:
sInputIds := ! Identifiers from mathematical program: sFlowshopConstraints + sFlowshopVariables + data { TimeSpan } + ! Identifiers from the section where the solution process is coded: Solution_Work_horses ; sInputIds := sInputIds + ! For bounds on variables, scaling factors, etc ! Ensure that all identifiers referenced in these variables ! and constraints are in the input case. ReferencedIdentifiers( sInputIds, AllAttributeNames, recursive: 1 ) + ! Stash list of identifiers to be returned. data { sOutputIds } ;
Now we only to construct the set of output identifiers, i.e. those identifiers that should be in the case send from the solver session to the client session. The client session only needs the Gantt Chart starts and durations. So that is simply:
sOutputIds := data { pGCJobStart, pGCJobDuration };
Now we have constructed the sets of identifiers that need to be passed from the client session to the solver session (sInputIds) and the set of identifiers to be passed from the solver session to the client session (sOutputIds), we need to pass this information to AIMMS Cloud, such that pro::DelegateToServer correctly handles this. For this purpose, AIMMS Cloud declares the following sets: pro::ManagedSessionInputCaseIdentifierSet and pro::ManagedSessionOutputCaseIdentifierSet.
The
pro::ManagedSessionInputCaseIdentifierSetneeds to be assigned before calling the procedurepro::DelegateToServer, for instance as follows:pro::ManagedSessionInputCaseIdentifierSet := sInputIds ;
The
pro::ManagedSessionOutputCaseIdentifierSetneeds to be assigned during the execution of the solver session. For instance as follows:if pro::DelegateToServer( waitForCompletion: 1, completionCallback: 'pro::session::LoadResultsCallBack' ) then return 1; endif ; prDoSolve(); pro::ManagedSessionOutputCaseIdentifierSet := sOutputIds ;
Summary
In this article, we’ve shown how to reduce the overhead of creating and communicating cases between the client session and the solver session.
Further Reading
See also the section on input and output case definitions in AIMMS Cloud documentation
The descriptions of the functions
ReferencedIdentifiersandSectionIdentifiers.
You can download the example:
2a. Flow Shop - ReducedCases.
