Data Integration with AIMMS Cloud Azure Data Lake Storage
Minimum AIMMS Cloud version: 2.50.1
Minimum AIMMS DEX version: 2.1.2.5
Every AIMMS Cloud comes with an Azure Data Lake Gen2 storage account (ADLS). The Data Exchange Library (DEX) provides functions to easily communicate with it, allowing you to import and export data onto/from the storage account. This route makes it easier to e.g. share exported data with external sources, or to import external data.
The process that will be demonstrated in this article will be:
creating a new container on the ADLS;
transferring a file to that newly generated container (making it externally available, or to be re-used again in the same or other AIMMS apps);
retrieving that same file again.
There are three possible flows to achieve this:
Using our ADLS toolkit, which can, when uploaded to the cloud, handle all these tasks by simply pressing the related buttons.
Using the ADLS-DEX route, in which we will use DEX functions specifically made for the ADLS to handle the flow.
Using the native DEX functions, which are the ‘native’ steps to be taken.
Only flow 2 will be discussed in detail below. If you want to follow flow 1, please refer to the toolkit page here.
Prerequisites
You need to have the Data Exchange Library installed. Visit this article for instructions on how to do this.
It is also good to understand the structure of an Azure Data Lake Storage. You can refer to this page to learn more about it, but important to know for this article is to look at the storage as if it’s a file explorer. The ‘folders’ are referred to as containers or file systems. It is possible to create new folders within other folders, creating so called paths. Files are always uploaded into a specified container. Files are also referred to as ‘blobs’ in the context of a Data Lake storage.
The ADLS-DEX Route
There are multiple DEX functions available to easily achieve what we want as they are created specifically for usage with ADLS. In this route you don’t have to worry about the creation of a SAS token for authentication (see below) or the arguments you’ll need to input, as the functions themselves will take care of everything.
Creating a New Container
Creating a new container (or, as called on the ADLS, ‘file system’) is easily done:
1!create a unique name for the container
2dex::schema::CreateUUID(testFS);
3testFS := "fs-" + testFS;
4
5!create the container with the above defined name
6dex::dls::CreateFileSystem(testFS);
Without errors, the container will be created with the given name.
Upload a File
Now we can continue with uploading a file from AIMMS to that newly created container on the ADLS:
1dex::dls::UploadFile(
2 testFS,
3 "DLSData/Azure Data lake v1/Bill Of Material.parquet",
4 "test"
5);
The arguments provided are:
the name of the container we want to upload to (which in this example is still the value in
testFS);the local path of the file to upload;
optional: a string parameter holding the path prefix of the location within the file system/container to which the file must be uploaded. If this path does not exist yet, it will automatically be created.
If you are unsure what the file system on the ADLS looks like, you can use:
dex::dls::ListFileSystemsto obtain the currently existing file systems (or: containers) on the ADLS;dex::dls::ListFilesto obtain the currently existing files within a given file system, including path(s) when applicable.
Note that it is also possible, with dex::dls::UploadFiles, to upload a set of files. If there are any subfolders within that set, these will automatically be created within the storage.
Without errors, the will be uploaded as specified.
Download a File
Now let’s download that same file from the ADLS:
1dex::dls::DownloadFile(
2 testFS,
3 "Bill Of Material.parquet",
4 "downloads"
5);
the name of the container we want to download from (which in this example is still the value in
testFS);the path of the file (including the file name, or only the file name if it is in the main container) within the file system on the ADLS to download;
optional: string parameter holding the local directory to which the file must be downloaded. In our example it is to the folder ‘downloads’ in the project folder.
Without errors, the file will be downloaded as specified. Now you can use a DEX mapping to map the data in the file onto your AIMMS model.
DEX Native Functionalities
The ADLS-DEX-functions used in the above flow are built with DEX-native functions. If you are interested in learning more about the underlying functionalities, you can access the functions by right clicking on the procedure and select the Attributes.
