Zip Library
https://img.shields.io/badge/Zip-white?style=for-the-badge&logo=github&labelColor=000081&color=1847c9 https://img.shields.io/badge/Repository-white?style=for-the-badge&logo=github&labelColor=000081&color=1847c9 https://img.shields.io/badge/AIMMS-24.6-white?style=for-the-badge&labelColor=009B00&color=00D400
Introduction
This toolkit library is used to facilitate compressing folders to files and reverting.
Instructions
This chapter is divided into three sections:
  1. Adding the Library
  2. Main Procedures
Adding the Library
To add and use this library to your project, first download the code and after, follow these steps on how to add an existing library to a project.
Main Procedures
Procedure zip::pr_zipFolderToFile(sp_folderName, sp_destinationFile)
Attributes
  • sp_folderName – the folder name to compress.
  • sp_destinationFile – the file name to store the archive into.
Procedure zip::pr_unzipFileToFolder(sp_fileName, sp_destinationFolderName)
Attributes
  • sp_fileName – the file that contains the archive.
  • sp_destinationFolderName – the folder to store the uncompressed contents.
Minimal Requirements
AIMMS Community license is sufficient for working with this example on Windows. To use the Linux version, you will need an AIMMS License for using on Linux, or allowed to deploy on AIMMS Cloud.
Release Notes
v1.0 (10/03/2025)
First official release as a toolkit library.
Earlier versions of Zip Library is available via previous article.
