Use a Multi-Objective Approach
In this article we will compare a multi-objective approach to separately solving single objectives.
Let’s take for an example a problem trying to find a healthy diet for a reasonable price. First let’s define our objectives:
minimize calories: I’m trying to lose some weight, so my healthy diet should be low in calories.
minimize price: a reasonable price means that it doesn’t have to be the absolute minimum, but should be within a close range.
Of course, I want to include minimum/maximum requirements for nutrients such as proteins. Please use the following project to follow this article:
Let’s use the multi-objective feature available since AIMMS 4.65 and CPLEX 12.9.
Procedure SolveMultiObj {
Body: {
ep_GMP := gmp::Instance::Generate( DietProblem );
p_retcode := GMP::Column::SetAsMultiObjective(
GMP : ep_GMP,
column : TotalCost,
priority : 2,
weight : 1,
abstol : 0,
reltol : 0.1);
if not p_retcode then raise error "Unable to set TotalCost as an objective" ; endif ;
GMP : ep_GMP,
column : TotalCalories,
priority : 1,
weight : 1,
abstol : 0,
reltol : 0.0);
if not p_retcode then raise error "Unable to set TotalCalories as an objective" ; endif ;
GMP::Instance::Solve( ep_GMP );
There are several remarks on the above:
Because the
TotalCostobjective has a higher priority value, it will be solved first.Because the
reltolargument on line 11 has value 0.1, subsequent solves will not increase the total cost by more than 10%.
Single Objective Approach
To be able to compare the multi-objective procedure to traditional single objective solves, there are also two solution procedures in this application:
MainExecution, a traditional single objective solve minimizing total cost.SolveMinCalo, a traditional single objective solve minimizing total calories.
Comparing Results
The application has both WinUI and WebUI interfaces, but WebUI is featured in the following screenshots.
Fig. 20 Results after minimizing total cost
Fig. 21 Results after minimizing total calories
Fig. 22 Results after running multi objective
The objectives are summarized in the table below:
Cost |
Calories |
Minimize total cost |
21.85 |
2698.40 |
Minimize total calories |
29.80 |
2546.40 |
Multi objective |
23.85 |
2576.40 |
As you can see, the multi-objective values are not as good as either of the individual objective values, but the multi-objective approach provides a good balance.
You may also find the CPLEX log interesting, as found in the file log/cplex 12.9.sta.
1Solve problem 'DietProblem' with 9 rows, 15 columns (0 binaries, 9 generals), and 83 nonzeros.
2
3MIP - Integer optimal solution: Objective = 2.1849999998e+01
4Solution time = 0.09 sec. Iterations = 20 Nodes = 0
5
6Solve problem 'MinCaloDietProblem' with 9 rows, 15 columns (0 binaries, 9 generals), and 83 nonzeros.
7
8MIP - Integer optimal solution: Objective = 2.5464000000e+03
9Solution time = 0.02 sec. Iterations = 13 Nodes = 0
10
11Solve problem 'DietProblem' with 8 rows, 14 columns (0 binaries, 9 generals), and 73 nonzeros.
12
13Multi-objective solve log . . .
14
15Starting optimization #1 with priority 2.
16
17Finished optimization #1 with priority 2.
18Objective = 2.1849999998e+01, Nodes = 0, Time = 0.05 sec. (0.45 ticks)
19Cumulative statistics: Nodes = 0, Time 0.05 sec. (0.45 ticks)
20
21Starting optimization #2 with priority 1.
22
23Finished optimization #2 with priority 1.
24Objective = 2.5764000000e+03, Nodes = 0, Time = 0.02 sec. (0.43 ticks)
25Cumulative statistics: Nodes = 0, Time 0.06 sec. (0.89 ticks)
26
27MIP - Multi-objective optimal
28Solution time = 0.08 sec. Iterations = 43 Nodes = 0
A breakdown of above log:
lines 1 - 4 for the first solve (minimize total cost)
lines 6 - 9 for the second solve (minimize total calories)
lines 11 - 28 for the multi objective solve.
