Change Hover and Select Effects for WebUI Charts
This article explains how to use CSS to customize the states of a chart or map widget on hover and on select.
Default Chart Behavior
These effects are the same for all the charts types.
Each chart has 3 states:
Default state – all bars have the same opacity
Hover state – hovered bar remains solid, opacity slightly reduced for the other bars
Selected state – selected bar remains solid, opacity is further reduced for the other bars
Nodes in the Map widget have a slightly different behavior
Default - all nodes have same opacity and no border
Hover - hovered node has a 1px border
Selected - selected node has a 2px border, opacity reduced for the other nodes
To customize the styles for these states, you’ll need to add a CSS file in the folder MainProject\WebUI\resources\css.
You can use the chart in WebUI Annotations - Widget and CSS support for a reference of elements and their corresponding CSS properties.
Example CSS
You can download the file below which contains the code snippets to change styles for the 3 states in charts.
In the images below, the first bar on the left has custom styles applied.
Hover
1/* Hover State */
2.annotation-bar_blue.chart-item:hover,
3.annotation-bar_blue.chart-item.is-hover {
4 /* fill changes */
5 fill: orange;
6 fill-opacity: .5 !important;
7 /* stroke changes */
8 stroke: aqua !important;
9 stroke-width: 4 !important;
10 stroke-dasharray: 5;
11}
Selected
1/* Selected state */
2.annotation-bar_blue.chart-item:active,
3.annotation-bar_blue.chart-item.is-active {
5 fill: yellow;
11}
