HOW-TO
  • Getting Started with AIMMS
  • Licensing
    • Activating Licenses Offline
    • Single-User License
      • Install Single-User License
      • Transfer Single-User License to Other Machine
      • Single-User License Troubleshooting
    • Network License
      • Install and Configure a AIMMS Network License
      • Install the AIMMS Network License on a Client Computer
      • Named Users in License Manager
      • Migrate AIMMS Network License Server
    • Academic and Community License
      • Academic and Community License Troubleshooting
  • AIMMS IDE
    • Installing AIMMS
    • Configuring AIMMS IDE
    • Keyboard Shortcuts
    • Sharing AIMMS Project Files
    • Export Code to Another Project
    • AIMMS IDE Troubleshooting
  • AIMMS Language
    • Version Control in AIMMS Projects
    • Identifiers & Data Modeling
      • Overview: Set, Subset, Index and Element Parameter
      • Types of Set
      • Local Binding vs. Default Binding
      • Remove Elements from a Set
      • Sets for Configuration
      • Multiple Indices for a Set
      • Handling of Integer Sets and Operators
      • Counting Elements in a Set using AIMMS
      • Modeling composite objects
      • ODBC data exchange of composite objects
      • Deploying AIMMS set functionality to composite objects
      • Reporting data over composite objects
      • Hierarchical composite objects
      • Using Calendars in AIMMS
      • Model Category Mapping of Items
      • Identifier Naming Convention
      • Check Computations with Units of Measurement
      • Localize Units of Measurement per User
      • Set Encoding Format
    • Procedures & Execution Flow
      • Interrupting Execution During a Single Statement
      • Generate Random Numbers
      • Convert String to Numerical Value
      • Run Batch Commands with AIMMS Command Line Tool
      • NBest Operator
      • Run Executable Files
      • Save a Case from an AIMMS Procedure
      • Finding Unused Identifiers
      • Write and Read AIMMS Data in Text Format
      • Libraries Initialization and Termination
      • InitialData Silently Leaves a Parameter Empty
      • Get Name of an AIMMS Case
      • Standardize Random Data in Distribution Functions
      • Simplifying Repetitive Loops in AIMMS
      • Zipping and Unzipping Files
      • Multi timezone applications
    • Performance & Memory
      • Measure Execution Time
      • Optimize Execution Time
      • Reduce Memory Usage
      • Monitor Memory Usage and Leaks
      • Investigate Memory in Use
      • Analyze Long Execution Time
      • Reclaim Memory Between Data Instances
    • Debugging & Logging
      • Identify Error
      • Handle errors and warnings
      • Customize Settings for Errors and Warnings
      • Get Log Files
      • Get More Log Information
      • Configuring the logging of sessions ran on a AIMMS PRO On-Premise
      • What is a dump file?
      • Sending a dump file?
      • In model tracing
      • Tracing Procedures
      • Monitor Identifiers for Changes
      • Identify Differences
    • Modeling
      • Set Stop Criteria for Math Programs
      • Debug Infeasible or Unbounded Results
      • Element after Last
      • Change the Default Solvers Used
      • Select Constraints and Variables
      • Solve in a Loop
      • Solve with Benders Decomposition in CPLEX
      • Modeling styles for using reference elements
    • Deploying
      • Create Responding Applications
      • Deploy an Application on AIMMS Cloud
      • Develop Multi-Platform Applications
      • Keep WebUI Active During Solve
      • Schedule Regular Jobs
      • Send and Receive Messages
      • Load solver session Results Manually
      • Number of running and pending solver sessions
      • Use the Progress Window in WebUI
      • Troubleshoot Unresponsive Applications
      • Show Intermediate Solutions
      • Publishing, Running and Deleting Apps on AIMMS Cloud
      • Waiting for sub jobs to complete
      • Interrupt the solver session
      • Investigate Behavior of AIMMS PRO Server Session (Job)
      • Using CI/CD with AIMMS
      • Modifying Session Timeout Duration for WebUI Apps
      • Encrypt Projects to Protect Intellectual Property
      • Communicate Data Changes in WebUI
      • Exporting aimmspack for WinUI or WebUI
      • Reduce Exchange Between Client Session and Solver Session
  • Algorithmic Capabilities
    • Adding a Solver
    • How to Link a Solver to AIMMS
    • Connect AIMMS with Gurobi
    • Adjust Engine and Solver Settings
    • Create Local Solver Configuration
    • Retrieve Solver Log Files in an AIMMS PRO On-Premise Setup
    • Retrieve Solver Log Files in AIMMS Developer
    • Constraint Programming
      • Color a Map with Constraint Programming
      • Use Constraint Programming to Solve ROGO Puzzle
      • Generate Multiple Solutions with CP Optimizer
    • GMP
      • The Generated Mathematical Programs
      • Implementing Continued Solves
      • Adapt Solve Procedure with Callbacks for GMP
      • Solve with Lazy Constraints
      • Solve MINLP Problems with AOA
      • Tune CPLEX Options from AIMMS
      • Automatic Benders’ Decomposition
      • Check if Variable Values Satisfy Constraints
      • Solve in Parallel with Asynchronous Solver Sessions
    • Mixed Integer Programming
      • Providing an Initial Solution to MIP Solvers
      • Speed Up MIP Solve
      • Use Alternative MIP Solutions with CPLEX Solution Pool
    • Multi-Objective Optimization
      • Use a Multi-Objective Approach
    • Non-Linear Optimization
      • Solving Convex MINLP Problems with AIMMS
      • AIMMS Outer Approximation Algorithm for MINLP (using GMP functionality)
      • Nonlinear Presolve Algorithm in AIMMS
    • Optimization Modeling
      • Model a Rounded Variable
      • Debug an Infeasible Model
      • Model Variables with Limited Values
      • Various (Integer) Linear Modeling Tricks
      • Minimize Objective Containing a min Operator
    • Scheduling and Planning
      • Optimize Shift Schedules
      • Optimize Scheduling for Project Planning
      • Reduce the Time Window for Scheduling Jobs
      • Vehicle Routing
        • Testing the Library
        • Explicit Dantzig-Fulkerson-Johnson Formulation
        • Capacitated Vehicle Routing Problem formulation
        • Implicit Dantzig-Fulkerson-Johnson Formulation
        • Miller-Tucker-Zemlin Formulation
        • Capacitated Vehicle Routing Problem Library
        • Time Windows
  • SENSAI
    • Sensai Apps
      • Hello World of SENSAI Apps
  • AIMMS Libraries
    • Add AIMMS Libraries
    • Data for Optimization Libaries
    • Repository Library
      • AIMMSXL Library (AXLL)
        • AIMMS Excel Library - AXLL
        • Read Columns of Data from Excel
        • Determine Data Ranges in Excel Files
        • Exchanging Data with Excel Files
      • Collaborative Data Management (CDM)
        • Integrate CDM Library to an AIMMS Application
        • CDM Troubleshooting
      • DataExchange Library (DEX)
        • How to Integrate the Data Exchange Library
        • How to use the Data Exchange Library for extracting files and data
        • Dealing with Different Data Types
        • How to create mappings for matrix-oriented data via name-binds-to
        • Reading Slices of Data via ExternalBinding Mapping Element
      • Email Client Library
        • Using Email Client Library
        • Create Email Templates
      • HTTP Client Library
        • Using HTTP Client Library
        • Extract Data from an XML File
        • Extract XML File from a Server with the HTTP Library
        • Retrieve Geographic Data with Google Maps API
        • Retrieve Geographic Coordinates with Google Maps API
        • Extract Photos Using the Flickr API
        • Convert Audio File with IBM API
        • Use the IBM Image Recognition API
        • Integrate AIMMS with Models Built in Languages Like Python or R
        • Integrate AIMMS with Python
        • Integrate AIMMS with R
      • Unit Test Library
        • Test Driven Development using the AIMMSUnitTest Library
      • WebUI Library
    • Runtime Library
      • Library of Functions and Procedures
      • Retrieve Value of Dynamic Identifier
      • Repeat Data with Model Query and Model Edit
      • Use Formulas as Data
      • Runtime Functions with Arguments
      • Create a Static AIMMS Library from a Runtime Library
  • AIMMS PRO On-Premise & AIMMS Cloud
    • AIMMS Cloud
      • Create PRO User Groups for Role-Based Access
      • VPN Troubleshooting Guide (Customer Side)
      • Migrate AIMMS PRO On-Premise Server to Another Machine
      • Download Server Session Log
      • Size AIMMS PRO On-Premise Hardware
      • Install CDM Service
      • Log CDM
      • Publishing to Offline Servers
      • Change AIMMS PRO On-Premise Service Account
      • Best Practices for Operating AIMMS Cloud
  • Integrations and Data Exchange
    • Exchange Data with the AIMMS Cloud
    • Linking to AIMMS
    • AIMMS Cloud ADLS
      • Data Integration with AIMMS Cloud Azure Data Lake Storage
      • Accessing Azure Data Lake Storage Externally
    • AIMMS Storage
      • Upload and Download Files on AIMMS Cloud
      • Secure File Access
      • Copy Folder Operations in PRO Storage
    • Databases
      • Connecting to and using the AIMMS Cloud Database
      • Which ODBC Drivers
      • How to Use Direct SQL Queries
      • Reading Relations and Indexed Sets from Databases
      • Adapt Model when Linked Database Table is Modified
      • Write Data to a Table
      • Write to a Database Efficiently
      • Write Selected Database Tables
      • Connection String for Access Database Files
      • Link an SQLite Database to a Project
    • Python-Bridge
      • Hello to the World of aimmspy from Python-Bridge
      • Nice to Meet You pyaimms from Python-Bridge
      • Orchestrating Contract Allocation AIMMS App from Python
      • Orchestrating the searoute Python Library from AIMMS
    • Rest API
      • Using OAuth2 for API Authorization with DEX
      • A Framework for Progress, Logging, and Error Handling of Tasks
      • LocationIQ Integration with AIMMS
      • Develop an AIMMS Service
        • Develop, Test, and Deploy an AIMMS Service
        • Development Architecture of an AIMMS Service
        • Conventions Used in the Examples Provided
        • Creating an AIMMS Server App
        • Using AIMMS Services with a Python Application
        • Using AIMMS Services with a VBA Client
      • OpenAPI
        • Overview OpenAPI in AIMMS
        • Using an API with OpenAPI Spec
        • Taking Multiple into Account Calling an OpenAPI REST API
        • Publishing an AIMMS Service
        • Python Client
    • Headless Applications
      • Headless Execution with AIMMS Application
      • Exposing the Vessel Scheduling as a REST Service
      • Start a Job via PRO API using Java
      • Start a Job via AIMMS PRO API using C#
    • Other Connectors
      • Writing to a Snowflake Database
      • Sudden Microsoft Access Reporting: “Make Sure this is a Valid Datasource”
      • Exchange Data with External Source
      • Create an External Function with Visual Studio
  • WebUI
    • Core
      • Best Practices in your Application
      • Dos and Don’ts
      • Showing Progress of Long Running Algorithms
      • Selecting Pages for Workflow Panels
      • Comparing Schedules from Scenarios
      • Disable Standard WebUI Functions
      • Uponchange with Arguments
      • Change Thousand and Decimal Separators in WebUI
    • Styling
      • Add Qualitative Color Palettes
      • Consistent Data Coloring on an AIMMS WebUI Page
      • Hiding Default Values
      • Using Scalar Border Annotation
      • Using Table Background Annotation
      • Hiding Widget Header
      • Centering Cells in Table Widget
      • Change Widget Styles with CSS
      • Adding a Logo to an AIMMS WebUI App
      • Change Hover and Select Effects for WebUI Charts
      • Display an On/Off Switch in Widgets
      • Adding an Icon on your Menu Bar
    • Widgets
      • Zoom and Scroll in a Gantt Chart
      • Sailing Across the World
      • Refreshing an Image Widget Without Changing the File Name
      • Adding an Icon on your Button
  • Software Evolution
    • Update the Project’s AIMMS Version
    • Overview: Deprecation of Compound Sets
    • Prepare for the Deprecation of Compound Sets
    • Support for Defining Procedure in New Compiler
    • Install Side-by-Side Drivers
    • Upgrade WebUI Page Actions
    • Upgrade Old WebUI Maps
    • Convert a GAMS Model or AIMMS 3 Model to an AIMMS 4 Model
    • Convert Files from DAT to DATA
    • Check Version Dependencies for AIMMS Developer and AIMMS PRO On-Premise
    • Using UNICODE in Maintained AIMMS Applications
    • Update WebUI to Newer AIMMS Version
    • Error Message “tlsv1 alert protocol version”
    • Evolution of AIMMS using Transport Layer Security
    • Unsupported Browser
    • Dollar or Pipe Sign?
    • Empty WebUI After Upgrade
    • Change the Frequency of Progress Updates
    • WinUI
      • Align Objects in WinUI
      • Change Views of 2D Charts in a WinUI Page
      • Enable the Page Manager
      • Add a Custom Startup Image in WinUI
      • More Logging of WinUI Published Applications
      • Openstreetmap Images Missing from Network Object
  • Examples
    • Examples vs Features
    • Demo Applications
      • Contract Allocation
      • Employee Scheduling
      • Knapsack Problem
      • Reindeer Pairing
      • Traveling Salesman
      • Vessel Scheduling
      • EV Charging Location
    • Functional Applications
      • Geolocation AbstractAPI
      • Demand Forecasting
    • Other Applications
      • Bandwidth Allocation
      • Cutting Stock
      • Diet Problem
      • Employee Training
      • Facility Location Choice
      • Farm Planning
      • File Merge
      • Inventory Control
      • Investment Portfolio Selection
      • Media Selection
      • Performance Assessment
      • Power System Expansion
      • Refinery Pooling Planning
      • Telecommunication Network Design
      • Two Level Decision
      • 3D Chart
      • AIMMS API
      • Arcs and Nodes
      • Calendar
      • Camping
      • Chance Constraints
      • Database Inspection
      • Database Interface Generation
      • Data Feed
      • Date Aggregation
      • Distributed Solver Sessions
      • Distributions
      • Email and Sound Support
      • Error Handling
      • Experiment
      • External Procedure
      • Gantt Chart
      • GIS Support
      • Goal Programming
      • Horizon
      • Indexed Page
      • Infeasible Data
      • Interrupt AIMMS Externally
      • Linked Objects
      • Model Edit API
      • Model Edit Functions
      • MPS Functions
      • Multi Start
      • Nested Solve
      • Oil Well Drilling
      • Power System Expansion RO
      • Print Pages
      • Rolling Horizon
      • Stochastic Programming
      • Tea Consumption
      • Chemical Engineering: Blending problem
      • Chemical Engineering: Chemical Equilibrium problem
      • Energy: Oil pipeline design
      • Energy: Water Distribution Network Design
      • Power Systems Planning - Methods and Applications
      • Engineering: 2D Strip Packing
      • Engineering: Goddard rocket
      • Engineering: Hanging chain
      • Engineering: Largest small polygon
      • Engineering: Robot arm
      • Engineering: Structural Optimization
      • Lot Sizing: Multi level bucket
      • Lot Sizing: Single level big bucket
      • Lot Sizing: Single level small bucket
      • Lot Sizing: Single level small bucket with two items
      • Miscellaneous: Asynchronous solver sessions
      • Miscellaneous: Multistart
      • Multiple Solutions: Dice problem
      • Production Planning: Machine scheduling
      • Routing: Capacitated Vehicle Routing Problem
      • Routing: Capacitated Vehicle Routing Problem with Time Windows
      • Telecommunications: Delay constrained routing
      • Telecommunications: Filter design
      • Telecommunications: Capacitated network design problem
      • Transportation: Aircraft Assignment
      • Transportation: Aircraft landing
      • Transportation: Piecewise linear transportation
      • Uncertainty: Synchronous Optical Network Ring Design
      • Uncertainty: Production Planning - Robust Optimization
      • Uncertainty: Production Planning - Stochastic Programming
      • Car Selection
      • Circle Packing
      • Data Reconciliation
      • Distribution Center Allocation
      • Economic Exchange Equilibrium
      • Flow Shop
      • Gate Assignment problem
      • Life Cycle Consumption
      • Project Analysis
      • Railway Stock
      • Sudoku
      • Traffic Equilibrium
      • Transport Model
  • Toolkit
    • Comparing Profiler Runs
    • Stopwatch Library
    • Zip Library
    • DataLake Tools
    • Control Panel
    • PRO Cloud Analytics
  • Recently Added
AIMMS How-To
AIMMS Logo
  • How-To »
  • Integrations and Data Exchange »
  • Rest API »
  • Edit on Github
Develop an AIMMS Service
These topics help you to
  • develop,
  • test, and
  • deploy
a service, by using the tasks methods of the AIMMS Rest API.
Last updated: Nov 04, 2025
Help & Feedback
Docs
Edit this page to fix an error or add an improvement in a pull request
Create an issue to suggest an improvement to this page
Product
Create a topic if there's something you don't like about this feature
Propose functionality by submitting a feature request
Support
Not what you where looking for? Search the docs
Remember we also have Community support
Still having trouble? Reach out to us
Next Previous
AIMMS Logo
Disclaimer Privacy Policy © 1989 - 2026 AIMMS B.V.
