CDM Troubleshooting
Issues with CDM Version Upgrades
Issue: When upgrading from earlier versions of CDM (e.g., 25.1.x) to newer releases (25.5.x or higher), users may experience:
  • Unexpected behavior when adding or committing set elements across branches.
  • Elements that appear in the local AIMMS session but are not committed to the CDM database.
  • Errors during checkout of snapshots, such as:
    packet buffer exhausted (8000, not continuing)
  • Snapshot checkout failing on first attempt but succeeding on the second run.
  • Inconsistent behavior depending on the CDM version used.
Cause: These issues may be related to:
  • Changes in the API methods and RPC format introduced in newer CDM versions.
  • Older CDM service instances still running, leading to mismatched RPC formats when applications connect.
  • Specific bugs in earlier releases of the 25.5.x line (fixed in subsequent maintenance versions).
Solution: Please follow the steps below.
  1. Upgrade to the latest CDM release:
    • Many issues (e.g., element handling and checkout errors) were resolved in CDM 25.5.2.1 and 25.6.2.1.
    • Always test against the most recent patch release of the target version.
  2. Ensure no legacy CDM services are active:
    • CDM services from older application sessions may remain running up to 5 minutes after the last connected session ends.
    • If multiple versions of the application are running with the same external service name, they may connect to an incompatible CDM service.
  3. Adapt the release process:
    • To avoid RPC mismatches, consider:
      • Using a different CDM service name for the new release.
      • Ensuring all older application sessions are terminated before deploying a new version.
    • Plan for a short delay (~5 minutes) to guarantee that old services are no longer active.
  4. Verification:
    • Re-run the checkout or commit procedure after confirming only the new CDM service is active.
    • If errors persist, test in a controlled local setup (SQLite/MySQL) to check whether the issue is environment-specific.
  • Future versions of AIMMS/CDM will make it possible to check active services directly in the portal or via API.
  • When encountering similar issues, always confirm the exact AIMMS and CDM version combination in use.
  • If reproducing locally is not possible, the issue may be tied to the PRO environment configuration rather than the CDM software itself.
