Publishing an AIMMS Service
This article illustrates how to create a service from an AIMMS procedure. It requires the following steps:
Create procedure that implements a task
Publish the application
Please use the following project to follow this article:
Procedure Implementing Task
1Procedure pr_runTask {
2 Body: {
3 block
4 ! Initialize
5 pr_initializeTaskData();
6
7 ! Read the request body.
8 pr_readData( dex::api::RequestAttribute( 'request-data-path' ) );
9
10 ! Actual solving of Operations Research problem at hand.
11 pr_actuallySolveEqualParallelMachineAsMIP();
12
13 ! Transform solution
14 pr_postProcessSolution();
15
16 ! write response body
17 pr_writeSolution( dex::api::RequestAttribute( 'response-data-path' ) );
18
19 onerror ep_err do
20
21 sp_taskStatus := errh::Message( ep_err );
22 errh::MarkAsHandled( ep_err );
23
24 endblock ;
25
26 ! the application-specific returncode that will be returned
27 ! via the task status of the job
28 return 1;
29 }
30 dex::ServiceName: equalParallelMachineTimeIndexedMIP;
31 ElementParameter ep_err {
32 Range: errh::PendingErrors;
33 }
34}
Some remarks about the highlighted lines:
Line 30: By specifying this line, the service
equalParallelMachineTimeIndexedMIPis linked to the procedurepr_runTask.Line 8: The request data is read from a file. The string
dex::api::RequestAttribute( 'request-data-path' )is the path to that file.Line 17: Similarly, the response is written to a file. The string
dex::api::RequestAttribute( 'response-data-path' )is the path to that file.
Deploying an Application on AIMMS Cloud
For an AIMMS Cloud with Tasks enabled, it suffices to publish the .aimmspack on that cloud.
