Install the AIMMS Network License on a Client Computer
Installing the AIMMS Network License Server
A network license is administrated by the AIMMS Network License Server on a server computer.
Download the AIMMS Network License Server from AIMMS Downloads.
Run the
AimmsLicenseServer...msiinstallation file and follow the prompts in the Installation Wizard.
Installing the Network License on a Client Computer
Prerequisites
Make sure you are connected to the same network as the server where AIMMS Network License Server is installed.
Install AIMMS (downloads of AIMMS can be found on our Downloads page).
Start AIMMS.
If no license is installed, a dialog will open automatically. If you previously installed a license, use the menu and click to specify a new license.
Select and click .
Type the name or IP address of the server computer (only specify a profile when you have multiple profiles) and click .
Click .
Your new license is installed.
If you previously installed another license, move the new license to the top with the button and tick the checkbox. The next time you start up AIMMS this license will be used.
In case of any problems during installation, activation, or running AIMMS, please contact AIMMS Support.
