Infeasible Data
Warning
This example requires AIMMS 25.1 or higher.
Direct download AIMMS Project CWL.zip
The capacitated warehouse location problem is the problem of locating a number of warehouses which have to service a set of customers, at minimum cost, where each customer has an associated demand and there are constraints on the total demand that can be met from a warehouse.
This model is infeasible. The new procedure GMP::Instance::GetInfeasibleData is used to find the cause of the infeasibility. To run the project, first run the procedure MainExecution to solve the model (which will be infeasible) and next run the procedure FindInfData to find the infeasible data. The procedure FindInfData fills a HTML message explaining the cause of the infeasibility, and it fills the .SuspicionLevel suffix of all parameters involved in the infeasibility with values ‘High’, ‘Medium’ or ‘Low’; it remains empty if the parameter is not involved.
You can also run this project using the WebUI by pressing ‘WebUI’ in the menu bar (after opening the AIMMS project). This will open a web page. Press the ‘Solve’ button to solve the model (it calls the procedure MainExecution), and press the ‘FindInexactData’ button to call the procedure FindInfData to find the infeasible data. A text message will be displayed and several data cells will be colored. To color the cells, the webui::AnnotationsIdentifier attribute of the parameters Capacity, Demand and AllocationCost is used. The colors are specified in the file ‘backgroundcolor.css’ in the following subfolder: MainProject\WebUI\resources\css.
Please note that the webui::ElementTextIdentifier attribute of the set Locations translates the elements of this set in the WebUI. It is also used to translate the elements appearing in the HTML message.
Keywords: Capacitated warehouse location, WebUI, Infeasible data
See also
