Telecommunications: Delay constrained routing¶
Direct download AIMMS Project DelayConstrainedRouting.zip
Problem type: MINLP (small)
Keywords: Outer Approximation, GMP-AOA, convex, lazy constraint callback
Description: The Delay-Constrained Routing Problem is a problem in telecommunications. Services are routed through a network, from source to destination, such that the delay of each service satisfies a certain guarantee. The objective is to minimize the total routing cost. This problem is solved using the AIMMS Outer Approximation (AOA) algorithm.
References: Hijazi, H., P. Bonami, G. Cornu�jols, A. Ouorou, Mixed-integer nonlinear programs featuring “on/off” constraints, Computational Optimization and Applications 52(2) (2012), pp. 537-558
