Headless Execution with AIMMS Application
Headless execution refers to running an application without a Graphical User Interface (GUI). This mode is essential for automation, batch processing, and deploying applications as services.
Depending on your deployment environment, you can choose the best method for your AIMMS application:
  1. On a local machine (Windows/Linux) using AimmsCmd.
  2. Inside a Docker container for portability and isolation.
  3. In the AIMMS Cloud for managed, scalable execution.
Headless Execution on Your Laptop
When your project files and data reside on the same Windows machine, directly using the AimmsCmd executable is often the simplest approach.
Directly Using AimmsCmd
The AimmsCmd command line follows a specific structure:
AimmsCmd [options for AimmsCmd] projectName.aimms [options for AIMMS application] < aimmscmdfile > logfile 2> errfile
This structure maintains a clear order of arguments:
  1. AIMMS Command Options: Optional, but critical for defining the execution. A common example is --run-only <procedure name>.
  2. Project Name: Mandatory (e.g., VesselScheduling.aimms).
  3. Session Arguments: Arguments passed to the AIMMS model, which are retrieved inside the application using the SessionArgument function.
  4. Input/Output Redirection: Used for sending commands to AimmsCmd and capturing logs.
Example A: Single Run Procedure with Session Arguments
This example demonstrates using --run-only to execute a specific procedure (pr_solveModelSessionArguments) and passing input/output file paths as session arguments.
 1echo on
 2
 3rem Use AimmsCMD to start Vessel Scheduling with session arguments.
 4
 5set AIMMS_VERSION=25.3.2.6-x64-VS2022
 6set AIMMS_EXECUTABLE=%localappdata%\AIMMS\IFA\Aimms\%AIMMS_VERSION%\Bin\AimmsCMD.exe
 7
 8pushd ..\AIMMSProject
 9
10%AIMMS_EXECUTABLE% --run-only pr_solveModelSessionArguments "VesselScheduling.aimms" data\VS_7Vessel_20Cargo.xlsx data\VS_7Vessel_20Cargo_Results.xlsx
11
12popd
13
14echo Current time: %time%
15
16pause
Remarks:
  • Line 10: The procedure pr_solveModelSessionArguments handles the entire workflow (loading data, solving, saving results) using the two file paths provided as session arguments.
  • pushd / popd: These commands ensure the AIMMS session’s working directory is the project folder, simplifying file path management.
Example B: Using an AimmsCmd Script and File Redirection
This method uses file redirection (< and >) along with an AimmsCmd script (sometimes called a properties file) to control execution.
 1echo on
 2
 3rem Use AimmsCMD to start Vessel Scheduling via an AimmsCmd script
 4
 7
 9
10%AIMMS_EXECUTABLE% "VesselScheduling.aimms" < single-run.properties > log/single-run.log 2> log/single-run.err
11
12popd
13
15
16pause
The input script single-run.properties contains a sequence of commands executed by AimmsCmd:
let sp_theExcelInput := "data/VS_7Vessel_20Cargo.xlsx" ;
let sp_theExcelOutput := "data/VS_7Vessel_20Cargo_Results.xlsx" ;
run pr_solveTheModel ;
quit ;
Example C: Starting the Application as a Service
AIMMS can be run headless as a REST service using its built-in API handler. This makes the application available for remote, asynchronous calls.
 1echo on
 2
 3rem Use AimmsCMD to start Vessel Scheduling as a service.
 4
 7
 8set VS_ROOT=C:\u\s\examples\application-examples\vessel-scheduling
 9set VS_PROJECT=%VS_ROOT%\AIMMSProject
10
11pushd %VS_PROJECT%
12
13%AIMMS_EXECUTABLE% --run-only dex::api::RESTServiceHandler "VesselScheduling.aimms" --dex::serviceTimeOut 30000
14
15popd
16
17echo Current time: %time%
18
19pause
Remarks:
  • Line 10: uses the procedure dex::api::RESTServiceHandler with the --run-only option to activate the service endpoint. The session arguments --dex::serviceTimeOut 30000 override the default timeout to 30 seconds.
Headless Execution in a Docker Container
Docker provides a portable, consistent environment for running AIMMS. Preparing an image involves packaging the application’s dependencies and defining how data is exchanged.
Preparing the Docker Image
The setup for a Docker image requires four core components:
  • AIMMS Executable/Installation: Based on the official aimms-eo Docker image, which is parameterized for the AIMMS version and includes necessary software components.
  • AIMMS License: Must be accessible in the /data folder, usually via mounting or inclusion. For a network license, the license.cfg file contains the server information: 1      network      <your license server>:3400.
  • AIMMS Application (Model): Copied or mounted to the image’s designated working folder, typically /model. This folder is the standard location for the AIMMS project inside the Docker image and is set as the working directory using the Docker option -w /model.
  • Data (Input/Output & Logs): Typically handled by mounted volumes as data varies per run.
    • Input Data (e.g., CSV, Excel) is mapped to the /inputs volume.
    • Output Data and Logs are mapped to the /outputs volume.
    • Logging Note: If you include a custom LoggerConfig.xml, ensure the file path redirects logs to the mounted volume, e.g., changing the file path value from log/aimms-log.txt to /outputs/aimms-log.txt.
Building the Image
The build script uses the aimms-eo base image and adds the license/model content.
 1echo on
 2
 3rem Builds a docker image with:
 4rem 1. license info in sub-folder "data" of aimms-eo checkout
 5rem 2. AIMMS application in sub-folder "model" of aimms-eo checkout
 6rem 3. AIMMS 25.3.1 installation
 7
 9
10pushd %VS_ROOT%\aimms-eo
11
12docker build -f Dockerfile.WithLicenseAndModel -t vesselscheduling:1.0.2.1 --build-arg AIMMS_VERSION_MAJOR=25.3 --build-arg AIMMS_VERSION_MINOR=1.0 .
13
14popd
15
16pause
Running AIMMS Inside the Image
Assuming the license and model are baked into the image, and data is managed via mounted volumes, here are the three execution scenarios:
Example A: Running a Single Procedure Directly
This is analogous to Example ‘a’ for local execution, using mounted volumes for data I/O.
 1echo on
 2
 3rem Script to execute a single procedure in an AIMMS app stored in a docker image.
 4
 5set VS_ROOT=C:\u\s\examples\application-examples\vessel-scheduling
 6set VS_INPUTS=%VS_ROOT%\inputs
 7set VS_OUTPUTS=%VS_ROOT%\outputs
 8
 9docker run --rm -i -v "%VS_INPUTS%:/inputs" -v "%VS_OUTPUTS%:/outputs" -w /model vesselscheduling:1.0.2.1 AimmsCmd --run-only pr_solveModelSessionArguments "VesselScheduling.aimms" /inputs/VS_70Vessel_100Cargo.xlsx /outputs/VS_70Vessel_100Cargo_results.xlsx
10
11pause
Example B: Executing an AimmsCmd Script
To correctly apply I/O redirection inside the container (not on the host), the AimmsCmd call must be wrapped in a shell command (e.g., using /bin/bash -c).
 1echo on
 2
 3rem Run vessel-scheduling by redirecting the AimmsCmd script as input to AimmsCmd in a docker container.
 4
 8
 9docker run -i -v "%VS_INPUTS%:/inputs" -v "%VS_OUTPUTS%:/outputs" -w /model vesselscheduling:1.0.2.1 /bin/bash -c "/usr/local/Aimms/Bin/AimmsCmd VesselScheduling.aimms </inputs/single-run.properties >/outputs/single-run.log 2>/outputs/single-run.err"
10
11pause
Alternatively, you can place the wrapped command in a script file, like aimmscmdrun.sh, and run that file:
#!/bin/sh
Then run it from the host: docker run -i -v "%VS_INPUTS%:/inputs" -v "%VS_OUTPUTS%:/outputs" -w /model vesselscheduling:1.0.2.1 /bin/bash -c /model/aimmscmdrun.sh
Example C: Running as a REST Service
This starts the application as a long-running service inside the container, mapping the internal service port (default 12003) to a host port using the -p flag.
 1echo on
 2
 3rem Start the VesselScheduling app with a REST API Service, handling tasks to solve the VesselScheduling problem.
 4
 8
 9docker run --rm -i -v "%VS_INPUTS%:/inputs" -v "%VS_OUTPUTS%:/outputs" -p 12003:12003 -w /model vesselscheduling:1.0.2.1 AimmsCmd --run-only dex::api::RESTServiceHandler "VesselScheduling.aimms"
10
11pause
Remarks:
Headless Execution in the AIMMS Cloud
When an AIMMS application is published to the AIMMS Cloud, headless execution and service management are fully automated.
You do not need to explicitly start a service (as with Docker or locally). When a task is posted to the application endpoint, the AIMMS Cloud automatically provisions resources, starts the project, handles the task, and manages the execution lifecycle.
