How to Enable the Page Manager in Recent Versions of AIMMS
In AIMMS versions 4.40.1 and higher, WebUI is the default user interface. When creating a new project, AIMMS gives you the option to select a default UI and if WinUI is not selected, the Page Manager will not be available in your project. This article outlines how to re-enable the Page Manager in your AIMMS project.
Setting the default UI when creating a new project
Re-Enabling the Page Manager
Follow the steps below to switch the default UI from WebUI to WinUI and re-enable the Page Manager
  1. Go to Settings > Project Options.
    ../_images/project-options.jpg
  2. In AIMMS Options, expand the Project directory and select Appearance.
    ../_images/appearance-options.jpg
  3. Select Default UI in the top panel and select the WinUI radio button in the bottom panel. Click Apply and close the Options window.
    ../_images/change-ui.jpg
Alternately, you can also click on the option Options with nondefault value to see the Default UI option there.
../_images/nondefault-value.png
Save your project to save this setting. You can now open Page Manager with the F9 key or from the menu in Tools > Page Manager.
Was this helpful ?
Send us your Feedback !
Last Updated: February, 2019
