Check if variable values satisfy constraints
This article explains how to check whether a given combination of value assignments for the variables in your model satisfy all the constraints to produce a feasible solution.
You could add an assignment constraint for each of your variables that fixes the variable to the given value and then solve the model again. If the solver returns with the status infeasible, you know that these variable values do not satisfy all constraints.
Or, better yet, use the GMP function GMP::Solution::Check.
Suppose we have the following simple model:
\({min}x\) | \(x + y \ge 5\) \(x,y \ge 0\)
and we want to check whether the assignment \(x=1\ ,\ y=1\) is actually a feasible solution.
First, add identifiers for the required variables (x,y,obj) and constraint to an AIMMS project.
Then, add a math program identifier that links these variables and constraints.
Finally, use the following code to check whether the assignment \(x=1\ ,\ y=1\) is a feasible solution:
!We want to check if x=1, y=1 is a feasible solution for our MathProgram
!First we must generate the GMP for our MathProgram
generatedMP := GMP::Instance::Generate(
   MP   : MathProgram ) ;
!Then we must assign the values we want to check to the variables
x := 1 ;
y := 1 ;
!Now retrieve the values from the variables in the model to
!solution number 1 of this generated math program.
GMP::Solution::RetrieveFromModel(
   GMP      : generatedMP ,
   solution : 1 ) ;
!We can now use the GMP::Solution::Check to check solution
!number 1.
GMP::Solution::Check(
   GMP       : generatedMP ,   !The Math program we want to use
   solution  : 1 ,             !The solution number we want to check
   numInfeas : numberOfInfeasibilities , !store # of infeasibilities
   sumInfeas : sumOfInfeasibilities ,    !store sum infeasibilities
   skipObj   : 1 ) ;           !Objective can be skipped
!Now we can check the number of infeasibilities. If there are no
!infeasibilities, it means the variables values satisfy all constraints
if numberOfInfeasibilities then
 message := "Variable values do not satisfy all constraints:\n"  ;
 message += "Number of infeasibilities = " + numberOfInfeasibilities + "\n" ;
 message += "Sum of infeasibilities = " + sumOfInfeasibilities ;
 dialogMessage( message ) ;
else
 dialogMessage("Variable values are feasible for all constraints") ;
endif ;
After running the above code, you will get the message that assignment \(x=1\ ,\ y=1\) does not satisfy all the constraints.
The example code above is available in a complete AIMMS project, attached below.
/Resources/193-check-if-variables-satisfy-constraints/Check-Solution.aimmspack
Last Updated: February, 2019
