Overview: AIMMS Excel Library
The AimmsXLLibrary can communicate with Excel files in server environments where Excel is not installed.
This library is especially useful when building WebUI apps for AIMMS PRO in a server environment.
The procedure follows the basic workflow illustrated below.
axll-workflow
Functions included with the AXLL library have a prefix axll.
Importing data from Excel files
  1. Add the AIMMSXLLibrary Library.
    Go to File > Library manager.
    Click Add System library… and select AIMMSXLLibrary. Click OK.
  2. Create a procedure.
    Create a procedure to import data from the Excel document. For example, ReadData.
    1. Open the Excel file:
      Use axll::OpenWorkBook to open your workbook.
      Tip: If you send a command to open a workbook which is already open, AIMMS raises an error. You can use an IF block to check whether a workbook is open or not, and open if it is closed or otherwise select the open workbook.
      WorkBookName := "zipcode-database.xlsx";
      if axll::WorkBookIsOpen(WorkBookName) then
          axll::SelectWorkBook(WorkBookName);
      else
          axll::OpenWorkBook(WorkBookName);
      endif;
    2. Specify a sheet of the workbook.
      Use axll::SelectSheet to specify which sheet of the workbook to pull data from.
      sp_Sheet := "Example";
      axll::SelectSheet(SheetName : sp_Sheet );
    3. Import data from the Excel file to your AIMMS project.
      Use the appropriate axll:: function to read data from the Excel sheet.
      The ReadTable statement will be:
      axll::ReadTable(
          IdentifierReference :  MyValue,
          RowHeaderRange      :  "A8:D18",
          ColumnHeaderRange   :  "E4:K7",
          DataRange           :  "E8:K18");
      Use axll::ReadSet to read in data for the set sStates.
      axll::ReadSet(
          SetReference    :  sStates,
          SetRange        :  "D2:D42523",
          ExtendSuperSets :  1);
      Use axll::ReadList to read in data ZipCodeState(z), which holds the state name that each zip code belongs to.
      axll::ReadList(
          IdentifierReference :  ZipCodeState(z),
          RowHeaderRange      :  "A2:A42523",
          DataRange           :  "D2:D42523");
    4. Close the Excel file.
      Use axll::CloseWorkBook to close the workbook.
      axll::CloseWorkBook(WorkBookName);
  3. Run the procedure.
    Run the procedure to import the data to your model. You can use the imported data for further operations and analysis.
Practical Example
For a practical example, read AIMMS Tech Blog: How to use the AIMMS Excel Library
Was this helpful ?
Send us your Feedback !
Last Updated: February, 2019
