Multiple indices for a set
This article explains how to use different indices to refer to the elements of a set.
Suppose we have a set Cities, then a parameter Distance would naturally be defined over 2 dimensions (from and to), both coming from this same set Cities.
One solution is creating two new sets CitiesFrom and CitiesTo, both subsets of the set Cities, comprising all elements of the set Cities and each with its own index.
../_images/Cities-attribute-window.png
However, an easier approach is to assign multiple indices to the set.
When you create a new set, you can directly add multiple indices to this set by typing all of them in the index attribute field, separated by commas (e.g. “city, cityFrom, cityTo”).
Note that after adding the index city and clicking Check, Commit, and Close, the index attribute is grayed out.
To modify the indices for this set, you can use the index attribute wizard by pressing the magic wand button just left of the input field for the index attribute. The wizard for the index attribute appears:
../_images/Cities-index-attribute-wizard.png
Alternatively, you can manually add an index identifier to your model tree for each index you want to add. For these index identifiers, you will have to set the Range attribute to the set corresponding to that index, as shown in the image below:
../_images/demo-explicit-index.png
Last Updated: February, 2019
