Repeat Data with Model Query and Model Edit
When constructing AIMMS models, we are usually able to handle repetition and structure by adding indexes. For instance, if we have built a model for the conversion process of a single machine, we do not have to duplicate the relevant model code when given an extra machine. Instead, we can use an extra index over a set of machines. However, there are situations where adding an extra index is not an option. This blog post will provide an example of such a situation, illustrating how the issue can be tackled using the AIMMS Model Query and Model Edit functions. Duplicating data with the AIMMS Model Edit and Model Query functions The example discussed in this blog post deals with the specification of data maintained per product. Note the differences in dimension and index domain of the following identifiers containing the data of the products, pr is an index in the set Products:
  • P1(pr)
  • P2(mat, pr)
  • P3(f, pr, t)
  • P4(pr)
We have the data for product ‘pr1,’ and we need to specify the data for product ‘pr2.’ The data for product ‘pr2’ should be the same as that of product ‘pr1,’ but with a different value for P4. So we first need to create a copy of the input data we have on ‘pr1’ (existingPr) for ‘pr2’ (newPr) as follows in AIMMS:
P1(newPr) := P1(existingPr);
P2(mat,newPr) := P2(mat,existingPr);
P3(f,newPr,t) := P3(f,existingPr,t);
P4(newPr) := P4(existingPr) ;
And then specify the differences:
P4(newPr) := 333 ;
When we start maintaining additional information per product, say P5(pr,reg), this added identifier requires us to visit the CopyProductDataProcedure code again. Hence, we need to add a similar line: <pre>P5(newPr,reg) := P5(existingPr,reg);</pre> Here we have identified a maintenance burden: to introduce a new identifier for products, we need to remember to extend the code of procedure CopyProductDataProcedure. Note that the difference in dimension and index domains of the involved identifiers prohibits the capturing of this structure by introducing an extra index. This ends our problem statement. Let us now try to tackle it in a generic manner. There is a clear pattern, for each identifier referencing a product pr, there is an assignment statement, and the product index pr within each statement is replaced by the new element and the existing element respectively. We will generate AIMMS code following this pattern using model query and model edit functions. Before we begin, however, a kind of pre-amble is needed. The model edit functions only operate on so-called runtime identifiers which are created inside a runtime library. In our example, we only need a single procedure. Therefore, we create the runtime library and its single procedure in the following two lines:
e_lib  := me::CreateLibrary("LibCreateCopyOfElement", "cce" );
e_proc := me::Create("ProcCreateCopyOfElement", 'procedure', e_lib);
Creating a runtime identifier results in a new element in the set AllIdentifiers. These new elements are assigned to the element parameters e_lib and e_proc. These element parameters are used reference the created library and procedure below. The body of the procedure is just some text that is compiled by the AIMMS compiler. Our job is to piece that text together. The trick is to know when to create a piece of text and what piece of text to create. “When to create a piece” is determined by considering each identifier from some subset of identifiers, and considering each argument in that identifier. This results in the following nested for/while loop:
for someIdent do ! For each identifier 'someIdent' to be processed:
  dim := IdentifierDimension(someIdent);
  outerArgPos := 1;
  while outerArgPos &lt;= dim do ! Consider each argument
    domInd := DomainIndex(someIdent, outerArgPos );
    domSet := IndexRange( domInd );
    if domSet = eElemRange then ! If the argument range matches the set.
    ! ... actually create a piece of text.
    endif ;
    outerArgPos += 1 ;
  endwhile ;
endfor ;
In order to know which piece of text to create, we first need to write a sample text, and then follow it as an example. The example text is a simple AIMMS assignment of the following form:
idName(i,'newElement',j) := idName(i,'existingElement',j);
A token is a single character or a small group of characters belonging together, for instance a comma, a parenthesis, a number, a name, or an operator such as “:=”. By following each token in the above assignment, and generalizing a bit, we come to the following AIMMS code. This code, in turn, will generate the requested AIMMS statements. First the left hand side:
bodyLine := someIdent + "(";
innerArgPos := 1 ;
while innerArgPos &lt; outerArgPos do
  domIndInner := DomainIndex( someIdent, innerArgPos );
  bodyLine += domIndInner + "," ;
  innerArgPos += 1;
endwhile ;
bodyLine += "'" + newElement + "'"   ;
innerArgPos := outerArgPos + 1 ;
while innerArgPos &lt;= dim do
  bodyLine += "," + domIndInner ;
  innerArgPos += 1;
endwhile ;
bodyLine += ")" ;
The assignment token:
bodyLine += " := " ;
The right hand side of the assignment, which is somewhat similar to the left hand side:
bodyLine += someIdent + "(";
innerArgPos := 1 ;
    innerArgPos += 1;
endwhile ;
bodyLine += "'" + existingElement + "'" ;
    innerArgPos += 1;
endwhile ;
bodyLine += ");" ;
Finishing up the line, and adding it to the body text:
! the n will generate a newline in the generated text.
bodyLine += "n" ;
! Add the assignment statement to the procedure body.
s_textOfProcBody += bodyLine ;
Now that we have the body text in s_textOfProcBody, we actually want to assign this text to the procedure:
ok := me::SetAttribute( e_proc, 'body', s_textOfProcBody );
Once the procedure is created and given its body text, we use the AIMMS compiler to check the text and generate executable code:
ok := me::compile( e_lib );
Here we compile the entire library, not just a single procedure. Note that the given example is relatively simple; only one runtime identifier is created. Normally, there are multiple runtime identifiers created, and the compilation of the library will ensure that they are all compiled. Once we have executable code, we can execute the generated procedure by an APPLY statement:
apply( e_proc );
A complete AIMMS model that provides the data duplication code, as a library, is available here: AIMMS project download
This completes the data duplication example. It illustrates the use of Model Query and Model Edit functions in the reduction of application maintenance costs. Other uses of Model Query and Model Edit functions include:
  • creating ad-hoc queries to explain model results, and
  • enabling modeler – end-user cooperative development.
Moreover, Model Query and Model Edit functions form a major building block when treating formulas as data. This, however, is a topic for another blog post. More information about Runtime libraries and Model Edit functions can be found in the Language Reference of AIMMS, section “Runtime Libraries and the Model Edit Functions.” Another example of the use of Model Edit functions was written in the post Retrieve Value of Dynamic Identifier.
Was this helpful ?
Send us your Feedback !
Last Updated: February, 2019
