Exchange data with the AIMMS Cloud Platform
Introduction
Most AIMMS applications import data from other systems and/or export data to other systems, beyond manual file upload into the app. For on-premise AIMMS installations that exchange data with other on-premise systems this can all be arranged using the standards, procedures and custodians of that on-premise environment. This document describes the options for exchanging data between on-premise systems and AIMMS apps running on the AIMMS Cloud Platform.
Figure 1 – Exchanging data between on-premise systems and AIMMS apps running in the AIMMS Cloud Platform
In this context the ‘application database’ is the database from/to which the AIMMS project reads/writes data (not to be confused with the AIMMS PRO database where apps, users and configuration of the AIMMS PRO instance are stored). This database is a paid option for the AIMMS Cloud Platform service.
Option Overview
We support three options for exchanging data between on-premise systems and AIMMS apps running on the AIMMS Cloud Platform. Each option has its application, no universal recommendation can be given.
  1. Via a connection with the Application Database that can form part of
    a customer’s set-up in the AIMMS Cloud Platform.
  2. Via the AIMMS PRO API, using the commands to upload and download
    files to/from PRO Storage.
  3. Via a web-service offered on the internet from the on-premise IT
    infrastructure with which the AIMMS apps interact using the AIMMS http-client library.
In the past we have supported other options such as a direct connection between the AIMMS apps in the AIMMS Cloud Platform and on-premise databases. We no longer support these as these options proved not secure enough, potentially slow down UI response times because of latency and proved too demanding for maintenance and support from both sides.
Option 1: Via a connection with the Application Database
Here the Application Database in the AIMMS Cloud Platform acts as decoupling connection point. On-premise systems can exchange data with this database (currently MySQL only), for example via syncing or via import or export components. AIMMS does not offer such components as there are many such components available both commercially and as open-source.
Figure 2 – Exchanging data via the application database in the AIMMS Cloud Platform
See https://dev.mysql.com/doc/index-connectors.html for details how to connect to MySQL databases.
All traffic takes place via a VPN tunnel that is initiated from the on-premise environment, so there is no need to permit incoming connections with associated security risks. This VPN (Virtual Private Network) tunnel offers high information security because it creates a virtual private connection by encapsulating and encrypting all data packets.
More details of the relevant parts of the AIMMS Platform architecture can be found in More details on AIMMS Cloud Platform architecture.
Option 2: Via the AIMMS PRO API
The AIMMS PRO API allows direct interaction with the PRO Back End and includes functions to upload or download files to/from AIMMS PRO Storage. AIMMS PRO Storage is the file system to which the AIMMS Apps running on AIMMS PRO have access. The on-premise environment will require a custom application (Java or .net) to access the AIMMS PRO API for this purpose.
Figure 3 – Exchanging data via the AIMMS PRO API
In order to get data files from the on-premise systems to an AIMMS app running on the AIMMS Cloud Platform, the on-premise custom application will need to upload the appropriate file(s) to the appropriate folder in the AIMMS PRO Storage. The developer of the AIMMS app will then use AIMMS functions to read these data files into the app.
The PRO API shares information security measures with the AIMMS PRO Portal such as lock-out on repeated logon failures, https encryption, optional IP range filtering and security event logging. In addition, the communications are secured by temporary tickets that can be seen as security tokens.
Option 3: Via a web-service
With the HTTPS Client Library for AIMMS an app developer can add functionality to an AIMMS app to interact with a web-service, for example retrieving data or submitting data. The on-premise environment needs to be extended with appropriate web services that are exposed to the internet, custom programmed for the application.
Figure 4 – Exchanging data via custom web services
Knowing the authentication and communication protocol of the bespoke web service, the developer of the AIMMS app can use the AIMMS HTTPS Client Library to add a procedure to the app that writes data to this web services or retrieves data from that web service.
For this option the information security measures are completely in the hands of the developers of the web service offered from the on-premise platform.
The following diagram depicts the part of the AIMMS Cloud Platform architecture relevant for exchanging data. The application databases are placed in customer-specific VPCs that include gateways to receive incoming VPN connections.
Figure 5 – Simplified diagram showing the relevant parts of the AIMMS Cloud Platform architecture
