Entering and Saving the Data
Entering set data
Manual data entry
Since this tutorial only contains little data, you are asked to enter it manually. (In the “My first AIMMS app” tutorial on the academy, data is imported from a database.) In this section you will encounter a standard data entry facility. Each identifier has an associated data page that you can use both to view data and to enter data.
Elements of the set Plants
To enter the two elements of the set Plants, you should execute the following actions:
open the attribute form of the set Plants,
press the Data button
move the mouse pointer to the data page as shown in Data page for the set Plants, and click in the empty edit field at the top of the data page,
enter Haarlem as the first element of the set,
press the
Enter
key to register this element,enter Eindhoven as the second element of the set,
press the
Enter
key to register this element, andclose the data page by clicking button (the data changes are immediately committed).
Fig. 19 Data page for the set Plants
Changing element names
To change the name of an element, just, select the element, press the delete button and enter the modified name in the same way as described above.
Elements of the set Customers
The elements of the set Customers are entered in exactly the same way as for the set Plants. The five elements are listed in Data page for the set Customers. Note that the last element Den Bosch contains a blank character.
Fig. 20 Data page for the set Customers
Entering parameter data
Empty tables
The data page of each indexed parameter is automatically filled with the elements of the corresponding sets. All that is left for you to do, is to enter the nonzero data values.
Supply data
In order to enter the data for the parameter Supply, you should execute the following actions (which are similar to the ones described in the previous section):
open the attribute form of the parameter Supply,
move the mouse pointer to the first data field and click,
enter the number 47,
press the
Enter
key to register the first value,enter the number 63,
press the
Enter
key to register the second value, andclose the data page by pressing Close button.
Fig. 21 shows the completed data page of the parameter Supply.
Fig. 21 Data page for the set Supply
Demand data
The data values for the parameter Demand are entered in exactly the same way as for the parameter Supply. The five data values are listed in Fig. 22.
Fig. 22 Data page for the set Demand
Cost data
The parameter UnitTransportCost is two-dimensional, and requires you to complete a table. The completed data page for this parameter is shown in Fig. 23.
Fig. 23 Data page for the set UnitTransportCost
Saving your data
Case management
AIMMS has the option to store the data values of all identifiers in what is referred to as a case. There are facilities both to save cases and to load cases.
Saving a case
In order to save the data that you just entered in a new case named Initial Beer Transport Data, you need to execute the following steps:
go to the Data menu and execute the Save Case command,
in the Save Case dialog box (see Fig. 24) enter the name Initial Beer Transport Data in the Name field (without the quotes), and
press the Save button to save your data.
Fig. 24 Save Case dialog box
Loading a case as the startup case
If a project in AIMMS is closed and subsequently reopened, you may want to reload your data. You may even want AIMMS to load a specific case automatically each time your project is started. This can be accomplished (without programming) using the AIMMS Options dialog box illustrated in Fig. 25.
go to the Settings menu and execute the Project Options command,
select the Project - Startup & Authorization folder in the option tree,
click on the Option Startup Case in the right-most window,
press the wizard button,
select the case Initial Beer Transport Data,
press the OK button on the Select Case dialog box,
press the Apply button on the AIMMS Options dialog box, and
finish by pressing the OK button.
Fig. 25 Options dialog box
Saving your project
It is a good habit to save your work regularly. The option settings above are also saved when you save the entire project. You can save the project by pressing the Save Project button . Note that saving a project does not mean that the data is also saved. Saving data requires you to save a case.
Loading a case manually
At any time during an AIMMS session you can load a case manually as follows:
go to the Data menu, select the Load Case submenu and execute the As Active… command,
select the desired case name in the Load Case dialog box (see Fig. 26), and
press the Load button.
Fig. 26 Load case dialog box
