Integrate GuardServerSession library with your AIMMS Application¶
This article is a companion article to Incident Handling for Organizations
This article describes how to use the GuardServerSession library to delegate jobs from your AIMMS app. The following steps need to be considered:
Adding the library
Change in delegation
Change in input and output cases.
Change in actions
Adding the library¶
A copy of the library can be obtained from here: GSS Library download
See also AIMMS How-To: Add AIMMS Libraries.
This library is dependent on the libraries:
AimmsProLibrary
AimmsWebUI
Change in delegation¶
We will use the attached AIMMS project as an example for this section: FlowShop.zip
In addition, we assume here that delegation is done as follows:
1 2 3 4 5 6 7 8 | if pro::GetPROEndPoint() then
if pro::DelegateToServer( waitForCompletion : 1,
completionCallback : 'pro::session::LoadResultsCallBack' ) then
return 1;
endif ;
endif ;
pr_WorkSolve();
We change this to:
completionCallback : 'gss::LoadResultsCallBack' ) then
return 1;
endif ;
endif ;
gss::pr_GuardAndProfileServerJob( 'pr_WorkSolve' );
Line 3: The procedure
will callpro::session::LoadResultsCallBack(sp_requestID)
and subsequently copy the error and profiling information to the tracked sessions container.Line 8: Instead of directly calling the workhorse, we guard it with the procedure
. This procedure will handle any errors during execution and at the end, collect profiling information.
Change in input and output cases¶
The set of identifiers saved in a case by the data session as input for the solver session is stored in pro::ManagedSessionInputCaseIdentifierSet
The set of identifiers saved in a case by the solver session for the data session is stored in pro::ManagedSessionOutputCaseIdentifierSet
If your application does not adapt these sets from their default contents (as described in AIMMS How-To: Reduce Exchange Between Client and Solver Sessions) before integrating with the GuardServerSession
library,
you do not need to do so after the integration either.
if your application does modify these sets from their default contents, then please add:
s_inputCaseIdentifiers
topro::ManagedSessionInputCaseIdentifierSet
in the data session.
s_outputCaseIdentifiers
topro::ManagedSessionOutputCaseIdentifierSet
in each solver session.
Change in actions¶
The WebUI provides various ways to invoke AIMMS procedures, including status bar, buttons, upload button, download button, item menus, widget menus, and page open. Each such invoked procedure should have the following pattern:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 | Procedure pr_actionTemplate {
Body: {
pr_enter(sp_gssTime, p_gssMiU, ep_logLev: 'info');
block
! Call procedure to do the actual work.
onerror ep_err do
gss::pr_appendError( ep_err );
errh::MarkAsHandled( ep_err );
endblock ;
pr_leave(sp_gssTime, p_gssMiU, ep_logLev: 'info');
Comment: "Sample action procedure"" DeclarationSection gss_logging_declarations {
StringParameter sp_gssTime;
Parameter p_gssMiU;
DeclarationSection error_reference_declaration {
ElementParameter ep_err {
Range: errh::PendingErrors;
Remarks:
Lines 3 and 10:
pr_enter
andpr_leave
these are used to generate contents for the.actionLog
File.AIMMS How-to: Tracing Procedures explains the workings of these procedures.
Lines 4, 6, and 9 delineate the business logic (line 5) from the error handling logic (lines 7,8).
Line 7: The procedure
gss::pr_appendError
stores the information of each error in the error container of the active session.Line 8: Mark the error as handled; the action procedure is usually the bottom of an execution stack - so it is the bottom of the error handling stack as well.
Some optional recommended application changes¶
Include the function
ProfilerStart()
at the top of yourMainInitialization
procedure. This will ensure that profiling information can be gathered and shared.Set the option
communicate_warnings_to_end_users
toon
. One of the purposes of the GuardServerSession is to share error information, which includes all warnings.As an aside, the default of the option
makes sense if extensive error handling measures are not taken in the application. Best practice is still to add extensive checking and careful error catching to your application.The option
maximal_number_of_warnings_reported
is switched to a high setting, like 1000.
Further Reading¶
This article is part of the series Indicident Handling for Organizations.
The next article in this series discusses how to build a user interface to use the GuardServerSession
library: UI for GSS
