Install UI of GuardServerSession Library
This article is a companion article to Incident Handling for Organizations and to
The GSS User Interface for specialists.
It contains a set of instructions to create the user interface for specialists working with the GuardServerSession
library.
After adding the library to your project, you can start building a user interface to that library in WebUI.
The rest of this article details the WebUI page GSS Session History Management
in this project and how you can replicate this functionality in your application.
Sidepanel
In this section, we create a sidepanel page first. This sidepanel will be used in the actual UI for specialists.
Create a side panel page with name sp_controls
Check the MainProject/WebUI/webui.json
file; the page sp_controls
should have “slug”: sp_controls_1
If not, the slug needs to be renamed at two places in the webui.json
file (with AIMMS closed).
The status bar of your app should be set to gss::sp_messageStatusBar
, or to a string parameter that contains this information.
Widgets on sidepanel
We start adding widget to the side panel as follows:
Scalar widget
shownSession
, titled:Selection Session & Type
Contents:
gss::ep_shownSession
gss::sp_shownSessionDescription
Miscellaneous property “Enable multi line”: 1.
Upload widget
UploadErrorWarningData
, titled “Upload Error Warning data”:procedure:
gss::pr_uploadErrorData
Download widget
DownloadModelLog
, titledgss::sp_titleDownloadActionLog
:procedure:
gss::pr_downloadActionLog
Download widget
DownloadErrorReport
, titled “Download error report for current session”:procedure:
gss::pr_downloadErrorReport
Download widget
DownloadErrorWarningData
, titled “Download error data for current session”:procedure:
gss::pr_downloadErrorData
Main UI for specialists
The page GSS Session History Management
has Action Upon Load
set to gss::pr_openPageErrorWarningProfiler
Tip
If you have a multi-page application, you might want to add this page to the group of “developer” or “control” pages in your application.
Make the page a grid page and give it standard layout 5, see Grid Layout for beautiful and consistent looking applications
The page extensions > side panels property should be set to `gss::sp_sidePanel
Add the following Widgets
Below are the widgets recommended to build a user interface for the GuardServerSession
library.
Table
ErrorWarningMessageTable
, titled:gss::sp_titleErrorWarningMessagesTable
Contents:
gss::ep_shownJobErrorSeverity
gss::sp_shownJobErrorMoments
gss::sp_shownJobErrorMessages
Pivoting:
Rows:
gss::i_jobErrorMessageNumber
Cols:
<Identifiers>
Store focus:
togss::ep_errorWarningSelectedNessage
Widget Extensions:
Widget actions:
gss::sp_widgetActionMessageList
Item actions:
gss::sp_itemActionMessageList
Move this widget to Area A of the grid page
Table
JobProfilerData
, titled:sp_titleProfilerOverview
Contents:
gss::p_shownJobProfilerHits
gss::p_shownJobProfilerGross
gss::p_shownJobProfilerNetto
Store Focus:
IndexIdentifiers
–>gss::ep_profilerDataSelectedIdentifier
Identifier Settings > Set slicing per index
gss::i_lineNumber
–> fixed element'0'
Widget Extensions:
Widget actions:
gss::sp_widgetActionIdentifierProfiler
Item actions:
gss::sp_itemActionIdentifierProfiler
Move this widget to Area B of the grid page
Table
ErrorWarningStack
, titled:gss::sp_titleStackMessage
Contents:
gss::ep_shownJobErrorNodes
gss::ep_shownJobErrorAttributes
gss::p_shownJobErrorLines
Identifier settings:
For all three, slice type index
to element parametergss::ep_errorWarningSelectedMessage
no decimals: 0
Store Focus:
gss::i_stackPosition
–>gss::ep_stackPos
Widget Extensions:
Widget actions:
gss::sp_widgetActionMessageStack
Item actions:
gss::sp_itemActionMessageStack
Move this widget to Area C of the grid page
Table
LineBasedProfilerData
, titled:gss::sp_titleProfilerDetail
Contents:
Identifier Settings - Set slicing per index
index
IndexIdentifiers
–> element parametergss::ep_profilerDataSelectedIdentifier
Move this widget to Area D of the grid page
Testing
To visually guide the adaption of the width of the columns of the tables, please run:
gss::pr_artificialDataGSSPage
to have an artificial warning message and
to ensure theGSS Session History Management
tables are filled properly.And then start manually adapting the column widths such that the contents fit neatly.
