Error and Profiling Results as Data¶
This article is a companion article to Incident Handling for Organizations.
Error and profiler data are stored in AIMMS’ sets and parameters; then serialized.
This way, they are shared between the end-users and specialists that use the application at hand.
This article discusses how this information flows through the GuardServerSession
library and which procedures can be used to
store error information.
Data flow of error information¶
The data flow of errors to support this user interface is organized as follows:
The red triangles are a stream of warnings and errors. These errors move via various steps upwards towards the blue box of errors shown in the User Interface.
There are two paths from “red” to “blue” for this error information, depending on whether the errors are generated inside the data session or in a solver session.
Data session errors¶
Errors occurring in the data session are collected by the error handler
gss::pr_appendError
ingss::dataSessionProfilerErrorData
which represents the orange box “Data session errors”When the WebUI page
GSS Session History Management
is opened, the data in the orange box is copied to the blue box, making the error data visible to the end-user.
Solver session errors¶
Errors in solver sessions are collected by the error handler
gss::pr_appendError
ingss::serverSessionErrorData
which represents the purple box “Solver session errors”.When the output case is loaded, this error information is loaded in the data session (to identifiers with the same name).
Immediately after, this error information is copied to a slice in the green big box “Solver sessions and uploaded sessions” by the procedure
gss::pr_saveTrackedSessionData
.In the WebUI page
, the selection widget controls which session’s error data is displayed. When you select a sessionID in the drop down, the corresponding error information is copied to the blue box and displayed.
Data flow of profiler information¶
The profiler information is captured at the end of a solver session, or at the start of opening the GSS Session History Management
Then it follows the same path as the error information through the application before it is shown.
Converting errors to data¶
Use the procedures pr_appendError
and pr_appendMessage
to convert errors and messages respectively to data in AIMMS identifiers.
The identifiers in which this data is stored are located in:
for data sessions
for server sessions
The procedure
pr_appendError(ep_err,sp_prefix)
appends the error to the open error collector.Arguments:
Input element parameter
ep_err
with rangeerrh::PendingErrors
. This is a reference to the error to be handled.Input string parameter
sp_prefix
. This can be used to prefix the error message stored from the message of the error referenced byep_err
Throws exceptions: None
Return value: None.
The procedure
pr_appendMessage(sp_msg,ep_lev)
Appends the messagesp_msg
sp_msg
. The message to be stored.Input element parameter
ep_lev
with rangegss::s_messageLevels
and default'info'
. The importance level of the messagesp_msg
Return value: None.
Converting profiling information to data¶
By adding ProfilerStart()
to MainInitialization
the AIMMS process will start collecting profiling information.
The GuardServerSession
library uses ProfilerCollectAllData()
to collect the profiling information;
no need to add calls to this procedure in your application.
