Use Multiple Indices for a Set
This article was originally posted to the AIMMS Tech Blog.
../../_images/index.jpg
Multiple indices for a set
You can use different indices to refer to the elements of the same set.
Suppose we have a set, Cities, and a parameter, Distance. We want to define Distance over 2 dimensions (from and to) for the same set, Cities.
If you didn’t know that AIMMS can handle multiple indices for a set, you might create two new subsets CitiesFrom and CitiesTo, containing all elements of the set Cities, and each with its own index.
Luckily, you can just assign multiple indices to one set.
When you create a new set, you can directly add multiple indices to it by typing all of them in the index attribute field, separated by commas (e.g. city, cityFrom, cityTo).
After the initial assignment of indices, you can’t edit in the index attribute of the set anymore. It will be grayed out when you open the attribute window.
../../_images/Cities-attribute-window1.png
Set attribute window with grayed out index attribute
Instead, use the index attribute wizard by clicking the magic wand icon just left of the input field. The wizard appears, as shown below.
../../_images/Cities-index-attribute-wizard1.png
Wizard for index attribute of set
Alternatively, you can manually add an index identifier to your model tree for each index you want to add. For these index identifiers, you will have to set the range attribute to the corresponding set as shown below:
../../_images/demo-explicit-index1.png
Explicit index identifier for set
Was this helpful ?
Last Updated: June, 2019
