Overview: Linking to AIMMS
This article provides information on possible interaction of AIMMS with other applications.
There are two possible situations:
  • Calling AIMMS from different languages/applications
  • Calling different applications/languages from AIMMS
Calling AIMMS
To call AIMMS from different languages/applications, your options are as follows:
Call AIMMS from ..
Possible
Method
AIMMS
Yes
AIMMS API
.NET
Yes
AIMMS PRO API
Java
Yes
AIMMS PRO API
C++ (.dll)
Yes
AIMMS API
Calling from AIMMS
To call different applications/languages from AIMMS, your options are as follows:
Call .. from AIMMS
Possible
Method
AIMMS
Yes
AIMMS API
.NET
Indirectly
See FAQ below
Java
Indirectly
See FAQ below
C++ (.dll)
Yes
AIMMS API
The following FAQs supplement the information in the table above:
Can I call AIMMS from .NET?
Yes, our AIMMS PRO API has native bindings for .NET, so you can use those to make calls to AIMMS directly.
Can I call AIMMS from C++?
Yes, you can use the AIMMS C++ API.
Can I call AIMMS from Java?
Yes, our AIMMS PRO API has native bindings for Java, so you can use those to make calls to AIMMS directly.
Can I use my .NET component within AIMMS?
No, but you could write your own C++ .dll that accesses your .NET component through the AIMMS PRO API.
Can I use my C++ .dll component within AIMMS?
Yes, if the exposed routines follow the AIMMS guidelines this is possible.
Can I use my Java component within AIMMS?
No, but you could write your own C++ .dll that accesses your Java component through the AIMMS PRO API.
